Motor mount ?????
Old Jan 30, 2006 | 12:56 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Motor mount ?????
I am doing my motor mounts right now and I got stock replacements. The drivers side, the rubber mount appears to be centered inside the shell, but the passanger side the rubber mount seems to be off to one side of the shell. The replacements I have are both centered inside the shell. Can someone point me in the right direction on how these mounts should be? Any pictures of the mounts side by side?
Zach
Old Jan 31, 2006 | 12:05 PM
Car: 91 Firebird
Engine: Turbo 355
Anyone???
Zach
Old Jan 31, 2006 | 12:46 PM
just2quickz28's Avatar
Car: 86 IROC
as far as i kno the two new ones should look identical, the old ones are probably shot and moved on ya, hope this helps
Old Jan 31, 2006 | 01:23 PM
Car: 91 Firebird
Engine: Turbo 355
When you say the same, do you mean each side looks the same? Or the new mounts look the same as the old ones. My old mounts dont look the same, is it possible one could of moved?
Zach
Old Jan 31, 2006 | 01:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Thirdgen shells are different left and right.
Old Jan 31, 2006 | 01:35 PM
Car: 91 Firebird
Engine: Turbo 355
Could someone explain this to me in better detail, I really dont want to screw this up. The two new mounts are the same, and my stock mounts are different.
Zach
Old Jan 31, 2006 | 01:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
https://www.thirdgen.org/techbb2/sho...hreadid=287789
Old Jan 31, 2006 | 01:56 PM
Car: 91 Firebird
Engine: Turbo 355
OK, good info but not what I'm looking for. The mounts where the three bolts go into the K-member. I got new mounts from the parts store, they are the same, my stock rubber peices appear to be different, the drivers side rubber is centered in the mount, and the passanger side is all the way to one side. I need to know what is what here.
Old Jan 31, 2006 | 05:14 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
You should still have the engine out of the car right? Just test fit the mounts on either side it. Either mount on the engine should fit inside both ears of the mount for the frame.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
