does it matter which side of the engine the motor mounts brackets go on
Old Apr 8, 2005 | 12:34 AM
onebinky's Avatar
IIRC, No.
Old Apr 8, 2005 | 09:36 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
You are correct, they will work on either side.
Old Apr 8, 2005 | 09:41 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Yes they will fit on either side, but there is a left one and a right one. What the difference is I do not know. If they have #'s cast in them post them and I'll see if I can figure it out.
Old Apr 8, 2005 | 07:01 PM
onebinky's Avatar
I actually just checked them, and they are different. One is a bit taller taller than the other one, I'll snap some pics and post the stamped numbers tonight if I remember.
Sorry for the mis-info guys.
Old Apr 9, 2005 | 01:14 AM
onebinky's Avatar
Alright, here's what I got:
14039486 and 334971
It looks almost like one of these may be aftermarket, or at the very least more recent GM parts. One of them had all kinds of scale and rust buildup, one was nearly perfect. Unless it had a nasty oil leak for most of it's life on just the one mount.
I won't know where each one goes until I pull the old motor out of the car, which won't be for a couple days.
onebinky's Avatar
I tried to post up a couple pics, but it appears that the server is having some difficulties
Old Apr 9, 2005 | 03:12 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
334970 - Left
14039436 - Right
Old Apr 9, 2005 | 03:31 AM
onebinky's Avatar
Originally posted by Apeiron
334970 - Left
14039436 - Right
From driver's seat, or from the front of the car? Any idea why those part numbers are so different?
Attached Thumbnails does it matter which side of the engine the motor mounts brackets go on-mount1.jpg
Old Apr 9, 2005 | 03:32 AM
onebinky's Avatar
Dirk got the attachment thing all fixed
Attached Thumbnails does it matter which side of the engine the motor mounts brackets go on-mount2.jpg
Old Apr 9, 2005 | 08:52 AM
Lo-tec's Avatar
Left is drivers side, right is pass side.
Old Apr 9, 2005 | 01:13 PM
Apeiron's Avatar
Engine: 383 Carb
Left and right are always the car's left and right.
Old Apr 11, 2005 | 06:50 PM
Got TPI?'s Avatar
Car: 1992 RS / 1986 Iroc
Engine: 350 Vortec / 305 TPI
Transmission: T5 / 700r4 on it's last leg
Just went out and looked at mine, can't see any difference in the mounts on the car or the clamps on the motor. Motor is getting ready to be put in, and this isn't something I want to hit me in the back when I'm trying to drop it in. Is the difference so small that it would be hard to tell which is which?
Old Apr 11, 2005 | 07:00 PM
Lo-tec's Avatar
There has to be enough difference that GM would make two different parts. I would pull yours and read the part #'s on them, and verify they are on the correct side BEFORE the motor goes in. It would suck a$$ trying to do it later.
Old Apr 11, 2005 | 07:32 PM
Apeiron's Avatar
Engine: 383 Carb
The only obvious difference I can see on mine without starting to measure things is that the "ears" where the bolt goes through the left-hand one are bent outwards slighty.
Old Apr 11, 2005 | 07:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
So, two left feet would be a good thing?
I never noticed any difference, but then, I've never had mine off!
Old Apr 11, 2005 | 10:07 PM
Got TPI?'s Avatar
Both of mine are bent out slightly. The motor is on a stand so looking at them is no problem, though I don't see a casting number on either of them (they are off the motor). Probably just my haste and paying more attention to their dimensions. They was on the motor when I got it though, stock 1998 vortec 350 out of a ck2500. I can get some pics tommorow to throw up if ya'll think it may help.
Old Apr 11, 2005 | 10:27 PM
Apeiron's Avatar
Engine: 383 Carb
Actually, the through-bolt holes are in different locations on the two. The right-hand mount has the holes closer to the block and lower.
Old Apr 12, 2005 | 01:31 AM
onebinky's Avatar
Here's some closeups of the ears:
Attached Thumbnails does it matter which side of the engine the motor mounts brackets go on-mnt1.jpg
onebinky's Avatar
Attached Thumbnails does it matter which side of the engine the motor mounts brackets go on-mnt2.jpg
Old Apr 12, 2005 | 04:34 PM
Apeiron's Avatar
Engine: 383 Carb
You can see the difference in the hole locations pretty clearly in those pictures.
Old Apr 12, 2005 | 05:16 PM
five7kid's Avatar
The front crossmember must not be symmetrical. Makes you wonder how many have been crossed over the years producing canted engine installations.
Old Apr 12, 2005 | 06:16 PM
BOTTLEDZ28's Avatar
Transmission: A4
well I have had mine off over a dozen times and never noted which side they came off and never had any big problems putting them back on. I have had some small issues getting 1 of the 2 bolts to go through all the way but Im surer everyonehas that problem once in a while. No issues here as far as I know. I started this post becuz I was curious. I wonder how important it really is to have them on the correct sides?
Old Apr 12, 2005 | 07:23 PM
Apeiron's Avatar
Engine: 383 Carb
There's been the occasional story of "I swapped engine mounts/engines and now everything sits higher", or "now my headers hit the steering shaft".
Old Apr 12, 2005 | 09:40 PM
allisonguy's Avatar
Car: 1984 camaro Z 28
Engine: 305 H.O. L-69
Transmission: 5-speed
My 84Z had the 14039436 on the right,and a 334971 on the left. My question is," What is the trick to getting to the nuts on the bottom of the mounts?" My engine is out and it still looks like a chore to get the mount bolts out. Thanks for any help.
Old Apr 12, 2005 | 10:45 PM
Apeiron's Avatar
Engine: 383 Carb
Some people have had luck with a swivel socket and series of extensions to get at the nuts. As long as the car's apart though, it might just be easier to take out the springs.
Old Apr 12, 2005 | 11:06 PM
Got TPI?'s Avatar
Take off the wheels and it's fairly easy if you have a lot of extensions and a swivel head. Key is just take your time, I did mine last Friday and took about 45 min with me by myself first time doing it (taking off the old and putting on the new). Impact wrench speeds up the process. Just take your time and remember it's a PITA!
Old Apr 13, 2005 | 05:32 PM
allisonguy's Avatar
Thanks for the information. Just went through the engine and the mounts looked pretty sad. Thanks again.
Old Apr 14, 2005 | 01:07 PM
Got TPI?'s Avatar
Finally found camera, mount brackets look the same to me Going to test fit it tommorow to make sure before I get any farther.
Attached Thumbnails does it matter which side of the engine the motor mounts brackets go on-sidebyside-copy.jpg
Old Apr 14, 2005 | 01:08 PM
Got TPI?'s Avatar
One more
Attached Thumbnails does it matter which side of the engine the motor mounts brackets go on-frontback-copy.jpg
Old Apr 14, 2005 | 02:09 PM
Apeiron's Avatar
Engine: 383 Carb
No numbers stamped in them?
Old Apr 14, 2005 | 02:54 PM
Got TPI?'s Avatar
nothing
Old Apr 14, 2005 | 08:52 PM
onebinky's Avatar
Is it possible that the mounts for the thirdgen F-body are vehicle specific?
Old Apr 14, 2005 | 08:55 PM
Apeiron's Avatar
Engine: 383 Carb
I'd say it's probable.
Old Feb 23, 2012 | 06:33 PM
capzoidz84Z's Avatar
Car: 84 Z,84 Vette, 62 Impala, 89 Fleet
Engine: 357
Transmission: 5-spd
Axle/Gears: 3.73 auburn posi, richmond gears
Re: does it matter which side of the engine the motor mounts brackets go on
Difference is slight angle and height. Odd number is always left side of vehicle, even number is right side. Just spent a couple hours referencing same question for an 84 Z that I'm putting together. My mounts are numbered 399371, 399372. Hope that helps.
Old Feb 23, 2012 | 07:35 PM
five7kid's Avatar
Kind of makes you wonder if it's still an issue after almost 7 years.
Old Feb 24, 2012 | 08:37 AM
Engine: 357
Transmission: 5-spd
Supposedly because of direction of tourque..........................................
Old Mar 15, 2012 | 10:26 AM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
The difference is the engine will move either to the left or the right about 1/4in. This is the reason why some people had trouble with SLP 1 3/4 headers hitting the steering shaft and the Super Ram hitting the wiper motor.
Old Nov 2, 2012 | 09:37 PM
austleadfoot's Avatar
Car: 86 ta firebird
Axle/Gears: borg 277:1
old post i know ,but if i wanted to move the motor to the drivers side 1/4 inch ,i could swap the mount housings over?
Old Nov 3, 2012 | 06:45 AM
Car: 86 ta firebird
only reason i ask , is the car is converted to right hand drive and having clearence issues with extractors to steering shaft
Old Nov 3, 2012 | 09:37 AM
skinny z's Avatar
Something I see that no one has mentioned is the 3/16" spacer that's designed to go between the mount and the block.
After the first couple of go rounds installing different engines, I had always noticed the the drivers side valve cover was higher than the passenger side. A level across the carb pad on the intake shows the amount that's it's off.
I found this spacer in my pile of parts and with it's installation in the passenger side, the engine sits perfectly level.
All OEM parts.
The first pic is the with the engine sitting in the mounts without the spacer, the 2nd pic shows the spacer position between the mount and the block.
Result, level.
It also made a difference with the header installation. Before the spacer there was contact with the cross member and the frame. After the spacer was installed, lots of clearence.
Attached Thumbnails does it matter which side of the engine the motor mounts brackets go on-img_5171.jpg   does it matter which side of the engine the motor mounts brackets go on-img_5172.jpg
Old Nov 3, 2012 | 10:05 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Ikes 91Z
Dec 9, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
timonator
Aug 11, 2015 09:56 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
