install bushings
Old Feb 11, 2006 | 11:46 PM
jerpoh's Avatar
install bushings
Lookin to redo my rear suspension. I bought new shocks and am probably gonna put new bushings but don't know anything about them. Is it hard to change the bushings or just as easy as the shocks. Just dont know anything about changing them, thanks. What are the tricky parts?
Old Feb 12, 2006 | 02:08 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Which bushings do you mean? The swaybar, lower control arm, or panhard rod bushings?
Old Feb 12, 2006 | 05:21 PM
Stevo's Avatar
Car: Pair of 92 Z28s
swaybar...simple unbolt and bolt in bushings
panhard bar...torch out press in
lower control arms...torch out press in
Old Feb 12, 2006 | 09:23 PM
jerpoh's Avatar
Doesn't sound too hard. It's just a little tricky trying to teach yourself stuff on your everyday driver. thanks
Old Feb 14, 2006 | 10:56 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
panhard I managed to hammer in my new bushings with a rubber mallet I think. Pretty easy.
The LCAs had a metal shell (ES bushings), and I needed a shop to press them in for me, $20.
Old Feb 14, 2006 | 05:22 PM
Stevo's Avatar
and how did you get the bushings out of the panhard? i didnt know they have to be pressed out or torched out after i started...ya i had a HELL of a time getting them back in...im upgrading to an adjustable one so im good now.
Old Feb 14, 2006 | 05:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
I think the panhard ones came out rather easily... I think I hammered them out? Maybe not.
For the LCA's, and probably the panhard, I just used my drill, and the cheapest drill bits I had, and drilled it into swiss cheese, then just pushed them out with my finger.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
NBrehm
Aug 5, 2015 07:57 PM
