proper way to install SFC
Old Feb 28, 2006 | 09:28 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
if i jack up one side of the car wit it on a level surface then put something under the wheels that will be the same height on both of them will this keep the car strait enough for the frame to be strait or do i Have to put it on a roll on lift? the only roll on lift i can find in my area is a shop that wants $300 to install a set of SFCs. but i know a guy who does awsome welding (he fixed my frame where it was broken for the steering box) and he said $100 to do it but he said he would just jack up one side of the car at a time to do it.
just thought about some thing. is it posible to lift oneside of the car put a jackstand under the front A-arm & the rear axel then lift the other side and do the same? or will the side done first slip off of the stands?
Old Mar 1, 2006 | 03:24 PM
crazyjim's Avatar
Car: 1989 Firebird
Engine: a monster
Get four of them bad boys and your set.
Old Mar 1, 2006 | 04:42 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
outta stock...
Old Mar 1, 2006 | 05:22 PM
crazyjim's Avatar
Car: 1989 Firebird
Engine: a monster
Originally posted by blyth18md
outta stock...
huh?
Old Mar 5, 2006 | 07:46 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
put the tires on cinder blocks
Old Mar 5, 2006 | 10:26 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Re: proper way to install SFC
Safer to jack up the front and put 2 jackstands under the a-arms. Then lift the back and put jack stands under the axle. Front first 'cause the p-brake will help keep the car from rolling, use wheel chocks or a block of wood behind the rear tires..
Old Mar 5, 2006 | 01:58 PM
xplane's Avatar
Engine: 2.8 MFI
thats cool i just talked to my welder dude yesterday and thats what he said he had planned on. i guess i didnt need to worry. thx for all your help tho.
Old Mar 5, 2006 | 07:40 PM
4RCEPWRD's Avatar
Car: 82Z28
can you not put the front on ramps and the rear on stands??
or does both front and back have to be on ramps?
Old Mar 5, 2006 | 07:48 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Just got done installing my SFC's 2 days ago. So long as the suspension is loaded, and the car is level....that's ideally what you want.
Vintageracer
Jan 10, 2020 05:33 PM
Stauf
Aug 24, 2015 08:31 PM
crazynights
Aug 21, 2015 06:53 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
