HELP Extreme camber Issue
Car: 85 Camaro
Engine: 383
Transmission: 4l60
So take a look at the obvious problem on my recently purchased car.. the tires on each side are badly cambered to the negative side....i know this is solid axle car, but WTF?!
I HOPE the axle isnt bent, and it wouldnt make sense for both sides to be the same way...A buddy told me that it could be a matter of the struts back there...i havent had a chance to look up under there due to the weather. I have ordered new shocks and struts and coils to install....Any ideas?
[IMG]
[/IMG]
[IMG]
[/IMG] Supreme Member
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
definitely weird. looks like the axle housing is screwed. get another one.
if you had irs, i would say bad struts/springs, but you don't have one
. Thread Starter
Car: 85 Camaro
Engine: 383
Transmission: 4l60
Originally posted by railroad
Any other signs of it being the previous owners weekend racecar
Car: 82z28
Engine: 406
Transmission: th350
Well to me the drivers side looks to be more of an issue. But if they were in fact bent equally it could have been done intentionally.
I believe in one of herb adams books he said up to 1* negative camber is fine, but I imagine this was a race only modifcation, and something youd want to perform with an alignment rack handy.
Ive read of a few folks heating there axle tubes to acheive this effect.
Originally posted by dock351
yes, im sure it was raced somehow. im getting this car put right. i ordered a whole different rear end, and coils, shocks, etc. Just wondered what exactly this problem was, two equally bent axles? could it have been done on purpose?
Car: 85 Camaro
Engine: 383
Transmission: 4l60
Most likely yes they purposely welded the negative camber into the axle by realigning the axletubes.
morrow
Jan 13, 2024 12:29 PM
