87 IROC rim offset
Old Mar 24, 2006 | 10:02 PM
rudefyet's Avatar
87 IROC rim offset
I just need to know the difference in inches between the front and rear rims...they're the 16x8 5 spokes
Old Mar 25, 2006 | 03:25 PM
Kandied91z's Avatar
factory 4 wheel disc non 1le is 0 mm front and +16 mm offset rear.
Old Mar 26, 2006 | 01:41 PM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
Hey, I have a question along these lines. What is the difference from an iroc with non-1LE 4 wheel discs and an iroc with front discs and rear drums?
I have an '88 Iroc convertable with rear drums. I want to get a set of torque thrust II's but I want to change to a disc brake rear over the summer. What are my options?
Sorry to highjack this thread but the search function is still down.
Old Mar 26, 2006 | 03:08 PM
Kandied91z's Avatar
well the drum option changed the factory offset of the rims. typically what gm did was put a very small spacer in order to fit the wheel. this being said the offset is probably closer to around 12-14mm in the rear but that's just a guess. do some research and find out.
if you are going to spend the money on nicer rims wait until your certain the location of the wheel offset.
as far as the fronts, 1-le typically has a better brake upgrade changing the offset again.
Old Mar 26, 2006 | 03:46 PM
Ah, Now I see. My rear has no spacers and my back tires appear to have a narrower track than the fronts. I will get some spacers, Use them with these rims and then with the TT II's. Then toss them when I swap rears.
Any suggestions as to what size Torque Thrusts and what offsets I should get?
Old Mar 27, 2006 | 01:26 PM
Anybody? I know there are about 44,000 guys running the Torque thrust II's
Old Mar 28, 2006 | 11:44 AM
Nevermind, The Search is back up!
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
g.l.mos
Aug 22, 2015 12:02 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
