People w/ sportlines, use front rubber isolator?
Old Mar 25, 2006 | 06:20 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I am in the process of rebuilding my suspension. I remember reading that some people take the front rubber isolator out and put a piece of garden hose instead because the front didn't sit low enough. My isolators are shot and will either have to get new ones or use something else.
Is there any aftermarket isolators?
Thanks.
Old Mar 29, 2006 | 10:37 AM
LilJayV10's Avatar
Engine: 406 Roller
ttt
Old Mar 29, 2006 | 12:42 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The isolator isn't very thick, and is there, I suppose, to cushion spring from pocket. I seriously doubt removing it would cause significant drop. I'd replace.
JamesC
Old Mar 30, 2006 | 04:47 PM
LilJayV10's Avatar
Engine: 406 Roller
anyone else? I know there is a few dozen people with sportlines
Old Mar 30, 2006 | 05:44 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
My isolater was MAYBE an 1/8" when it wasn't being crushed? I poped it back in because it would make an almost unnoticable drop even with the sportlines.
Old Mar 30, 2006 | 10:59 PM
LilJayV10's Avatar
Engine: 406 Roller
thanks for the input. I ordered new ones today. won't be in till monday. I was going to try and get the car back together this weekend. it's ok though, i need to study for my criminal law test anyway.
Jason
Old Apr 2, 2006 | 12:26 PM
MdFormula350's Avatar
I know people take out the rear ones since those isolators are real thick and they use hose on the top coil instead to make the rear sit just right to match the front.
I read a few post from people that do it to the rears, cant recall people doing it for the fronts since those isolators are pretty darn thin.
I am about to take out my rear ones for my prokit since that darn rear end still sits to high and i have had enough of looking at it.
Old Apr 2, 2006 | 08:20 PM
Stevo's Avatar
Car: Pair of 92 Z28s
I just got done with my pro-kit install i droped a good inch off the front and the rear only droped about half an inch. I dont like the gap in the rear at all...then again im thinking sportlines or other 2" springs in the future...
Old Apr 2, 2006 | 08:58 PM
rleprechaun's Avatar
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
I installed Pro springs with new spring seats. With your sportlline springs you should be plenty low enough with new seats. Stay away from the garden hose it will eventually rub through and it will be metal to metal.
Old Apr 2, 2006 | 11:31 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Me too rear gap is excessive with mine. I plan on getting some stock springs and cutting them down.
Old Apr 3, 2006 | 05:19 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
After I installed my sportlines (without the rubber coil spring isolators), I noticed that the ride was jaw breaking and noisy...so I bought new isolators from GM and shaved the tops of them down a little and installed them in the front and rear. They helped out alot with noise and smoothed out the ride alot. If you can deal with losing some of the "lowness" of your ride then I recommend it, for me it worked out well since I have long tubes which are ridiculous for ground clearance.
Old Apr 3, 2006 | 06:33 PM
Demon355's Avatar
Have any pics Neil?
Old Apr 3, 2006 | 07:06 PM
LilJayV10's Avatar
Engine: 406 Roller
I think I do remember that it was for the rear springs. My front isolators were shot so I will replace them. Once I get the car done I will post some pics. Thanks for the replies.
Jason
AussiePr0nCar
Mar 6, 2020 04:04 PM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
deracer
Apr 11, 2016 12:04 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
MORREALE5
Sep 13, 2015 09:01 PM
