Front end Alignment
Old Apr 1, 2006 | 12:26 AM
rleprechaun's Avatar
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
Front end Alignment
What are the front end alignment settings for a 1987 TransAM (1) street (2) ultra high preformance street (3) road race?
Old Apr 2, 2006 | 01:03 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Here's two links for ya.
https://www.thirdgen.org/newdesign/f...tml#suspension
http://www.fl-thirdgen.org/alignmentspecs.html
HTH
Old Apr 2, 2006 | 08:15 PM
Stevo's Avatar
Car: Pair of 92 Z28s
What do some of you other guys do? I have to take my car in for alignment tommaro should i tell him the high performance street specs or just have him align it "the regular way"
Is this all just a matter of how long my tires will last?
Old Apr 13, 2006 | 10:09 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
ttt
Old Apr 13, 2006 | 11:38 PM
BADNBLK's Avatar
COTM Editor
A couple of years ago I had the alignment shop use autocross alignment specs on my car. I got these specs from a 82-92 performance book (with red z28 on cover). I felt like this did a great job with handling, but I did not think that the reason why I had the car aligned was because I just lowered it. I recently had the car aligned again, and had them do the "norm", it is so much better than previous. I would recommend a standard alignment unless you really need it.
Old Apr 14, 2006 | 07:28 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
why was this stock alignment so much better? comfort, tire wear, handling???
Old Apr 14, 2006 | 10:07 AM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
BADNBLCK, what were the Autocross settings that you had that you didn't like? I was thinking about going with this for an Alignment...I thought it would be a little more aggeessive on the street...
Camber - .5
Caster + 4, + 4.5
Toe 1/16 In
Old Apr 14, 2006 | 11:14 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thats EXACTLY what specs im going with. should be agressive for the street but not too bad to kill my tires and still keep some straightline stability
Old Apr 14, 2006 | 12:12 PM
BADNBLK's Avatar
COTM Editor
When I had the autocross settings it felt improved, but I think the improvement I was really feeling was the lowering springs, not the alignment. After getting it straight with factory settings the steering felt more responsive and less tendancy to pull on smooth roads, and even less pull from ruts in the pavement. My car would follow the ruts in roads badly I though mainly from the 275x17s on the front, but it is now improved with factory alignment. As far as what the setting were, I would have to pull out that book and get them for you to compare. I will try and do that for you tonight after work.
Old Apr 14, 2006 | 11:22 PM
Car: 1987 TransAm
Alignment
I sure want to know you aggresive settings. I am running in a track day May 20.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
