competition engineering subframe connector
Old Apr 3, 2006 | 04:43 PM
85SILVERBULLET's Avatar
Car: 1985 TRANS AM
Engine: 383 SBC
i purchased a set of the CE subframe connectors part#cee-3046 from summit
they are semi weld on and bolt on. these connectors bolt on to the original crossmember holes and then you have to cut channels out of the floor pans and then weld them to the connector. that is all well and dandy but the connector does not weld to any solid part of the car. summit says that the kit must be used with a ce formed rear rail kit but they do not have a part # for the kit. I just checked the ce website and they dont even list a rail kit for the car. any ideas would be great..
Old Apr 4, 2006 | 11:53 AM
idoxlr8faster's Avatar
Car: 91 firebird, 02 silverado z71
Engine: 383 with custom TBI/5.3L
Transmission: 700r4/4L80E
Axle/Gears: 3.42posi/3.92locker
THESE FRAME RAILS ARE FOR USE WITH CE'S UNIVERSAL FORMED REAR RAILS. IN OTHER WORDS: THIS KIT IS DESIGNED TO BE USED WHEN YOU ARE TUBBING THE CAR AND NARROWING THE REAR FRAME!!!! THE PRINT IS FINE, BUT IT IS NOTED IN THE SUMMIT CATALOG. THEY SELL THE FULL BOLT ON KIT FOR ABOUT $230 THAT WORKS WITH YOUR STOCK FRAME, HOWEVER YOU WOULD HAVE TO REROUTE YOUR EXHAUST PIPE!
HOPE THAT HELPS, ITS A MISTAKE THAT IM SURE HAS BEEN MADE BY MANY, AS I SEE MANY OF THOSE SUBFRAME CONNECTORS END UP ON E-BAY IN NEW CONDITION.
Old Apr 4, 2006 | 04:34 PM
Car: 1985 TRANS AM
Engine: 383 SBC
[QUOTE=idoxlr8faster]THESE FRAME RAILS ARE FOR USE WITH CE'S UNIVERSAL FORMED REAR RAILS. IN OTHER WORDS: THIS KIT IS DESIGNED TO BE USED WHEN YOU ARE TUBBING THE CAR AND NARROWING THE REAR FRAME!!!! THE PRINT IS FINE, BUT IT IS NOTED IN THE SUMMIT CATALOG. THEY SELL THE FULL BOLT ON KIT FOR ABOUT $230 THAT WORKS WITH YOUR STOCK FRAME, HOWEVER YOU WOULD HAVE TO REROUTE YOUR EXHAUST PIPE!
HOPE THAT HELPS, ITS A MISTAKE THAT IM SURE HAS BEEN MADE BY MANY, AS I SEE MANY OF THOSE SUBFRAME CONNECTORS END UP ON E-BAY IN NEW CONDITION.[/QUOTE
when i bought the connectors out of summit in 2003 they did not have any kind of notes in the catalogue. but my issue has to do with the rail kit. do i have to make one or does someone make on already. My car is not back halved and the connectors are already installed. It would have been nice if i the instructions there was some kind of note to this.
when i bought the connectors out of summit in 2003 they did not have any kind of notes in the catalogue. but my issue has to do with the rail kit. do i have to make one or does someone make one already. My car is not back halved and the connectors are already installed. It would have been nice if in the instructions there was some kind of note to this.
Last edited by 85SILVERBULLET; Apr 4, 2006 at 04:35 PM. Reason: Automerged Doublepost
Old Apr 4, 2006 | 07:34 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Holy Caps batman!
Old Apr 5, 2006 | 10:14 AM
Car: 1985 TRANS AM
Engine: 383 SBC
[QUOTE=Dirtbik3r]Holy Caps batman![/QUOT
bwahahhahahhahah!!!!
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
