Edelbrock Panhard Bar
Old Apr 5, 2006 | 02:38 PM
IROCZ89TTTPI's Avatar
From: Stow, OH (About 10min from the Tallmadge Summit Racing)
Car: 1989 IROCZ
Engine: 305 TPI(Building 383Twin Turbo)
Transmission: TH700R4
Axle/Gears: 3.42 (Under construction)
I was just wondering if anyone has one or has used one, and also if they liked it or not. Just ordered one, and was kinda indifferent about it because my buddy broke his Edelbrock Torque Arm and it was on a mildly built 350.
Old Apr 5, 2006 | 02:45 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Spohn, a board sponsor, is highly recommened.
JamesC
Old Apr 5, 2006 | 04:21 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
The PHB does not undergo the kind of stress that a TA does. Basicly if you compare the material from one piece to the next and they are the same; the pieces have a similar strength.
Old Apr 5, 2006 | 05:00 PM
Car: 1989 IROCZ
I understand that, I was just wondering about the stength and longevity of the product. But thank you for your input.
Old Apr 5, 2006 | 05:36 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
UMI has some nice pricing on EBAY
i got it for 65 shipped
not bad
and it looks really nice too
poly bushings and all
i didn't get the adjustable, didn't need it
Old Apr 5, 2006 | 05:59 PM
Souseless's Avatar
Car: 89 WS6
Let me try this again. Look at the links. Edelbrock.com - Suspension - Suspension Components
Edelbrock Performance Products
Spohn Performance, Inc.
I do not like poly ends so of the above choices I only like one of them. The two adjustables with poly have a threaded adjuster in the middle of the tube which is a bad location for the weak point. The non adjustable poly versions well , lack adjustment.
Look at the design and look at the materials and your answer should become obvious. By the way the rodends do not add noticable harshness or road noise on a PHB. My choice is rodends but there are cheaper comparable products out there.
Old Apr 5, 2006 | 08:28 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I have the spohn SFC and it seems to work just fine. I think they give you a choice between black and red.
Old Apr 5, 2006 | 10:25 PM
Car: 1989 IROCZ
Well what about the solid Edelbrock PHB, thats the one I ordered. Its stock ride height so I dont think Im really gonna need an adjustable one.
Old Apr 6, 2006 | 11:55 AM
Car: 1988 SC Camaro
Engine: 305 TBI
ya, i think if you're not lowering your car, then a non-adjustable one will be fine. My Spohn is a solid (non-adjustable) bar and i have no regrets at all about buying that instead of an adjustable. (Although i have no plans for lowering my car, they already ride low from the factory!)
Old Apr 6, 2006 | 12:24 PM
Souseless's Avatar
Car: 89 WS6
The Spohn part is stronger and has grease fittings. When it comes to strength the outside diameter is more important than the wall thickness. The Edelbrock should be fine though. You really want one with the grease fittings if you are using poly and I was not sure from the picture on the website if they were there.
Old Apr 6, 2006 | 09:17 PM
Car: 1989 IROCZ
Well I got it today, it seems great. It also has grease fittings. Thanks everyone.
Old Apr 10, 2006 | 06:11 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
I have had the edelbrock piece for 3 years now and the car seemed to stick to the ground better. No strength problems either.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
meeklay812
Oct 1, 2015 03:46 PM
