ABOVE THE PANHARD BAR???
Old Apr 5, 2006 | 06:23 PM
jrsfast84's Avatar
Car: 84' firebird
Engine: 440"SBC (N/A)
Transmission: th-400
DOES ANYONE KNOW WHAT WOULD HAPPEN IF I TOOK OFF THE BAR ABOVE THE PANHARD BAR THAT CONNECTS TO THE FRAME, THEIRS SOME WEIGHT THERE THAT COULD BE TAKING OFF THE CAR, WHAT DOES IT DO, I'M JUST CURIOUS.
Old Apr 5, 2006 | 07:02 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Are you talking about the upper panhard bar support bar? The one that has the body mount end for the panhard bar.
I wouldn't mess with that centers your rear end under the body. I once had a panhard bar snap on my old buick ('90). When you made any kind of turns the whole body would roll enough the car would zigzag. Not at all fun to drive. Basically without it the body is just resting on the spring, shocks, sway bar, and lower control arms back there. You'd be dog legging like crazy.
Old Apr 5, 2006 | 08:24 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I've asked the question beofre regarding that bar...it can be referred to as a "Track Bar," although i don't know its specific name...i wonder what would happen if it was removed since the panhard rod has the function of side-to-side support, i wonder what the function of the other bar is...
Old Apr 5, 2006 | 09:46 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
the one above the panhard rod spreads to stresses from the PHR to both sides of the car. go ahead and remove it and the first time ya go around a hard corner that mount is gonna bend and probably tear loose.
Old Apr 5, 2006 | 10:59 PM
jrsfast84's Avatar
Car: 84' firebird
I was looking for the right answer and it's staying off, i know someone who has it off and runs in the ( 8's ) and the rear never moved.Maybe he'll comment on this. Thanks for the info., to me ; thats just weight that the car doesn't need. ( REMOVE IT. ) .
Old Apr 5, 2006 | 11:27 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if you live your life driving in a straight line, then removing something that soley effects your cars ability to corner wouldn't hurt eh?
But if you're driving it on the street, taking corners, then it's probably best to keep it there.
Old Apr 6, 2006 | 11:52 AM
Car: 1988 SC Camaro
Engine: 305 TBI
Ok everybody, take that track bar off your cars, then drive it for a few months taking corners really hard, and then let me know how you made out, then maybe i'll take mine off...
Old Apr 6, 2006 | 03:21 PM
xplane's Avatar
Engine: 2.8 MFI
OK go here http://www.deadbird.org/home/index.a...es&r=40&pid=42 and look at Part 9 under Rear suspension. it says right there that it is the brace for the PHR.
Old Apr 6, 2006 | 06:26 PM
Camaro0605's Avatar
Car: 1991 RS
I would think that it takes the load of the panhard bar off the oneside of the car and distributes it to both sides of the car. The panhard bar bracket goes into the passenger side frame rail, and the upper bar connects the bracket to the driver side frame rail.
Old Apr 11, 2006 | 12:48 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Its called a "Track Bar Brace," According to Chilton's Manual...I couldn't find any info about it though
Old Apr 11, 2006 | 05:48 PM
radialtireking's Avatar
Car: 85 Camaro
Engine: 437" small block
Transmission: glide
Axle/Gears: 3.70
Mine has been off my car for the past 5 years. Over 10,000 street miles and 100's of passes at the track. Car has been 8.96 @ 150 with a 1.27 60'. Due to the set up of my car I do not takes corners at extreme rates of speed. The car does see plenty of windy back roads due to where I live though. There has been absolutely no movement in the bracket. However I would not recomend it's removal on a car that is cornered extremely hard or sees any kind of road coarse time. On a street/strip car that isn't set up for blasting around the turns full bore it does not need to be on the car.
Old Apr 11, 2006 | 05:57 PM
Sonix's Avatar
Car: 1982 Trans-Am
good god, what kind of powerplant do you have?????
you can drive that on the street?
Old Apr 11, 2006 | 06:14 PM
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
It's a pretty wild small block. 436" with nitrous. It goes 10.0's on the motor and the 8.96 pass was on a 250 shot. I only have a few passes on it and there is definetly more left in it. As for driving it on the street. It's actually pretty streetable. It has full interior and never overheats. It even gets ok gas milage for a 1050 dominator. I've gotten as much as 10 mpg on a recent trip to a car show.
Old Apr 11, 2006 | 10:21 PM
laiky's Avatar
Knock, Knock.
Who's there?
Darwin.
Darwin who?
It's worth the pound or two it weighs.
Old Apr 11, 2006 | 10:55 PM
jrsfast84's Avatar
Car: 84' firebird
Thanks Jeff, so where do you test the most, car looks good and runs, i got my car down to 3075lbs. w/ me, from 3325lbs.w/me (250lbs lighter), now i just have to get the car to go straight out instead of straight up!!!. JR1.
Old Apr 12, 2006 | 06:11 AM
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
Cecil County on saturdays. You can get alot of runs in and the track is usually good.
Old Apr 13, 2006 | 12:50 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally Posted by laiky
Knock, Knock.
Who's there?
Darwin.
Darwin who?
We all know it's not there due to stock HP numbers...
Old Apr 13, 2006 | 09:37 AM
laiky's Avatar
Doesn't have anything to do with HP. Its not there for strait line accelleration. The PHB locates the rear laterally and as such takes the full load of the whatever lateral G forces your car can generate. The support bar reinforces the mount and transfers that load across both sides of the chassis. thay acually make stronger versions for the 4 gens. If your building a dragstrip only car, probably not an issue, but dealing with the constant loading and reversal of loads you will see on the street or road course/autocross, and lack of constant inspection you might be seeing a catastrofic failure.
Old Apr 13, 2006 | 12:15 PM
xplane's Avatar
Engine: 2.8 MFI
ya that would be cool to watch see someone take a corner and that mount fails wonder how far the axle would flop to the side Hmmm.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
