Question about my 91 camaro RS Frame
Old Apr 6, 2006 | 10:52 PM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
Ok i just have one question..i was driving my car and i got hit on the drivers side front bumper. the kid did enough damage to push in the subframe to the radiator support...which intern pushed the steering box back about 1/2 inch or mabye 5/8 inch..the only reason i know this is the steering gets caught up on the bolt that is sticking out of the a arm that is connected to the wheel. Now this sounds like he pushed it back pretty far but it actually isnt. I have driven the car since then and it drives without a pull. my question is 1 could i just cut off the affected part and weld on a straight peice that i can get from my newly aquired camaro or do you think that i a frame shop should be able to pull the subframe back out...i can pull out the fender support if needed and the radiator support i would take off of the parts one and whatnot..do you think that it is salvageable...the only reason i like it so much is it is a 91 rs it has t tops and it is teal green...lol and so mis my parts car except it isnt t tops...hard top.
here are some pics they are high resolution but you will see what im talkin about
http://home.comcast.net/~gmzombie/Picture001.jpg
http://home.comcast.net/~gmzombie/Picture006.jpg
http://home.comcast.net/~gmzombie/Picture005.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
