My opinion of Spohn Coilovers...
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
Well I installed my coilovers last weekend along with some Lakewood 70/30's and I thought that the installation went very well. Not only was it easy to install, but it actually came with directions and every single piece of hardware. The only things that had to modify were the struts a small amount (took 10 min) and one of the 1/4" spacer plates needed to be modified a little bit. Install was 100x easier than a conventional spring, and has the height adjustability on top of it. On the how well it performs catagory I cant comment too much yet because I was only able to drive around the block a few times...but from what I can tell they handle the turns fine. I need an alignment first so i will be able to comment on that once I get everything finished. Honestly, so far, I think it was definatly worth the money. If anybody has any questions, feel free to ask. I was too excited to get them installed to take any pictures so I dont have any right now.
Chris
Chris
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
You guys are the ones I need to talk to! I am considering Spohn's coil overs in the front and rear OR going with the Shockwave's from Air Ride Tech. How is the ride with the coil overs? Is it harsh, jaw-breaking etc.? Do you have single or dual adj shocks in the rear and can you adjust them to get a somewhat smooth, comfortable ride and a stifffer ride for handling?
I think I would rather go with coil overs for $$$$ and ease of install'n and less crap to mess with i.e., compresor, tank, air lines, etc....
Thanks guys!
Neil
Thanks guys!
Neil
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
your gonna need to do something to stringthen the Strut towers ro there gonna deform if ya run your car hard. your putting all the weight of your car on that piece of sheetmetal where as using the stock placement all it held was the rebound forces. there was a member who had pics of how his fenders buckled and warped cause the strut towers bent.
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Hey, Just wondering what spring rate you used with the LS1 engine. I bought the #325 but am starting to think maybe i should have gone with #300 due to the weight reduction of the LS1 plus deleting all the AC parts.
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Originally Posted by crazyjim
Now... you can adjust height and stiffness independently correct?
Yup, just change the springs out for another set and the "stiffness" is changed. . Couple that with a set of adjustable struts and there you go.
I "should" be picking up my coil over kit and a-arms this weekend, so for the gent that was asking about how high and low you can go I'll snap a few pics.
FWIW I got the 325# springs.
Car: 1989 Firebird
Engine: a monster
awesome, you mind me asking what you ended up paying for your struts? And who you went through/ brand?
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
I'm with xplane on this one. The strut towers are simply not designed to handle the load of the entire front end on them. I not gonna badmouth spohn or his product here, I'd never install a kit like that without some kind of reinforcement to the frame.
Car: 1991 Camaro
well spohn did a little more reinforement then the other companys by running a plate to spread the load out more. I have been running them on some pretty bad roads with now problem yet. But i'm not going to say that its just as strong as stock either.
Thanks guys!
Neil
Thanks guys!
Neil
Originally Posted by blyth18md
Id like to pictures of the coil-overs at max settings, both highest and lowest.
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
ive got them on my car, but ive yet to drive it, motors not even in it. anyways, the car is built for road racing, and ive been 2nd thinking, either going back to stock setup, or heres the idea. an 8 point was definite, still debating 10, but i figure if i go 10, ill go 12, have the bars come through the firewall as close to the fender as possible, and have the follow the contour of the wheel well and running into the frame right behind the radiator. then taking some tubing, have one piece in the front, and one in the back, and then have a large piece of 1/4 steel run between the roll bar and the supports. possibly cutting out the stock strut tower area so theres more adjustability, because right now i dont have much because the spring runs into the sheet metal. i havent had a chance to have it on a rack obviously, so i dont know just how much ive lost
Engine: 2.8 MFI
It may have a plate but that wont stop the shock mount trying to bend to where it hangs strait over the frame rail rather than at an angle. if your gonna run those at the very least install a STB to keep them from bending in. just look at the geometry of the car.
https://www.thirdgen.org/forums/susp...onversion.html
Look at the red firebirds fenders right above the wheels.
Car: 1991 Camaro
Yea i have read that, right now i'm runing spohns upper strut mounts, and a BMR 3 point STB, so that should help, plus i've pulled close to 200 lbs. off the front end.
Engine: 2.8 MFI
I dont think they will make a difference enough to be worth the crap you have to go through to make them work properly.
Car: 1991 Camaro
So only option then was to run coil overs, thats the same reason why "92camaroLS1" is running the coil over set up as well.
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
. Senior Member
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I understand the issues that some have had with coil overs but you cant compare one company to another, nor can you take one members problems and say that it will happen to everyone that uses coil overs. The spohn unit is alittle better built and does not pinpoint the pressure to just the upper strut mount area. There is a large plate that is placed underneath the strut tower then you use a much stronger upper strut mount which sandwiches the upper strut tower in bewteen them. It spreads the stress area out for alittle less direct force to just the upper strut tower. Everyone knows the cars were not designed to use coilovers so to just repeat that time and time again by people who dont use coil overs is crap. I am not pro Spohn but i do like his products, just wish his business practices were a little better as i am still waiting on a K-member from hawks in which he is the main hold up.
Car: 1989 Firebird
Engine: a monster
What if you tried something like this to prevent the distortion of the fenders. Obviously not EXACTLY this, it's not a very good design IMO. But if you ran off a knee bar in the cage, down to frame in front of the fender well. And also brought a support down behind it, then mounted the coil overs the same way his shocks are mounted... plus the added support of an obviously custom made strut tower brace.
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
thats basically what my idea is but im still not sure what im going to do, unless somebody wants to buy a spohn kit with 325#, got a profab k member and a arms too. i could just throw my stock stuff back on that would be money towards the trans, and its almost done
Engine: 2.8 MFI
jtmiller92: Thats not where the problem is. it is that the WHOLE STRUT TOWER FROM THE FRAME RAILS UP WILL SHIFT. that is what you have to prevent.
crazyjim: You could co that route but i know that when i convert over i dont want to go that far.
Well ideally, Id like to have something to prevent any damage, but really I wouldnt even know where to start. Maybe I will just put a 3pt strut tower brace. My front end is pretty light as well though.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
well my front end is heavy with a iron BBC just under 2000 pounds on the front tires for close to 2 years now with coil overs and I have no problems, using the spohn mounts and pa coil overs on 90/10 lakewoods...street and strip and the roads around here are about as bad as they get!
Engine: 2.8 MFI
It could and probably does depend a lot on how new a car and how badly it was abused before you got it that will make a difference to. but as easy as it would be to add some sort of extra braceing to the car why not? your not loosing much if any weight by moveing the spring but mabe a better suspention geometry for cornering so you should already have extra braceing in place.
Engine: 2.8 MFI
thats mostly what i was refering to. but i dont think it would be that hard to make a plate that covers the bottom portion of the strut tower under the Strut mount and bend 2 pieces of tubing to run down the side of the fender well to the K member. then either weld on a bracket to the kmember and bolt the brace to it or just weld it on. i have looked at my car and have it planned out for when i get the money to switch over. esentially i will be extending the Kmember up the strut tower.
Engine: 2.8 MFI
probably afterwards. another thing to think about is that your need a solid strutmout rather than a rubber one cause those will fail under the weight of the car. heck i had one tear on me just doin some hard cornering with out even a STB.
Edit ignore that i didnt realize that then Spon kit included them.
hell the more i look at the spohn kit the easier it looks like it would be to add a brace just weld the tubing to spohns bottom brace and then to the K-member.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
darwinprice
17
Oct 11, 2015 11:51 PM
