Front Tires rub after front end work...
Old Apr 11, 2006 | 01:42 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Having some troubles here. Installed a PaRacing K member and Spohn tublar a-arms w/ spohn front end rebuild kit. Put everything together and now I can't turn my wheel more than 1/4 of the way without the tires rubbing. I notice something wasn't right with the k member the way it was built didn't look right (Bar was A LOT lower than the oil pan and other flaws) so we took it out and left the spohn a arms on...but still had the same problem. What would cause this? Are the a arms to short or something and pulling the tires in close enough to where they rub? I am going to put the stock a arms back in and see what happens. Would the front end rebuild kit effect this at all? Any help would be appreciated. Just want to get this front end done so I can finish the car. Or is there a way to adjust the a arms?
Old Apr 12, 2006 | 08:30 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
If you turn the wheel, the back of the tire will rub the fender and rub on one of the screws on the inside of the fender. This happens on both driver and passenger.
Here is the thing. Put the stock a arms back on...perfect clearance. Can turn the wheel all the way to the left and the right with no rubbing. Ideas?
Old Apr 12, 2006 | 12:11 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Mabe you have the arms on the wrong sides?
Old Apr 13, 2006 | 01:50 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Correct sides. Still nothin.
Old Apr 23, 2006 | 11:39 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Any updates to this?
Old Apr 28, 2006 | 06:44 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
None. I just took my k member and a arms off and sending the a arms back to Steve Spohn so he can look at them. K member was junk (PaRacing).
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
