Spohn Adj TQ Arm for T56 -->Thoughts? Did a search..
Old Apr 13, 2006 | 09:33 PM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
Anybody have any thoughts/comments on Spohn's Adjustable Torque Arm for the T-56?? I did a search and didnt find anything..
Dan
Old Apr 15, 2006 | 10:37 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
love mine. nice and solid. i would recommend the poly torque arm mount to cut down on the noise transferred to the cross member, especially if you have rod ends on the rest of the suspension like i do.
Old Apr 16, 2006 | 09:26 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Yes, they are the ****. Only way to go if you're ditching the stock arm.
Old Apr 17, 2006 | 12:57 PM
thanks for your opinions guys..
if the mods see this can you move this to the trans/drivetrain page of TGO??? I think thats a better spot for this post...
Also.. on Spohn's page (for the Adj. TQ Arm) it lists Front Mount Type-
Poly Bushing.. or Chrome Moly Sperical Rod end. Which one should I opt for? My car is gonna be a street/strip car. If the chrome moly sperical rod end is used for "hardcore drag racing" I figure its not for me then.. I always here about how chrome moly is lighter but still prone to cracking on the street...
Thanks in advance..
Dan
Old Apr 17, 2006 | 01:05 PM
Mine works fine.
It's a real tight fit around where the end of the arm goes next to the trans; but with care, and several trial fits and readjustments, it is now happy. The driveshaft loop bracket also hangs down sort of low, but given how it has to be located in this chassis, I don't see how that could have been avoided.
The poly is probably better, if you drive it on the street. Rod ends transfer ALOT of road and drive train noise to the chassis.
Old Apr 17, 2006 | 01:13 PM
Trial fits and readjustments??? Are you talking about adjusting the pinion angle?? And as for the DS loop bracket hanging low.. would I have to worry about that if my car isnt lowered??
Dan
Old Apr 17, 2006 | 01:23 PM
No; I'm talking about where the front end of the arm, goes next to the transmission. You'll see. There's a huge bolt and a sort of link arrangement, and depending on how long the arm is adjusted to (it has about 2-3" of adjustment) the head of that bolt can hit the transmission as the suspension travels, if it's not set right.
My car isn't lowered either. But if I go over a really serious dip, it will scrape. There's one place I can make it bottom out any time I want.... it's where one street turns into an e-way entrance ramp after it crosses another that has a kind of high crown, and then goes up a hill. If I go over that spot at more than 35 mph or so, it will scrape when it comes down off the crown on the other side and gets to the lowest point and then starts going up the hill.
Old Apr 17, 2006 | 09:44 PM
@ZZKKER's Avatar
do not get the rod end torque arm mount, especially if you use rod ends on everything else as this will transfer all rear end noise and expansion joint noise to the seat and floor.
also, if i were to buy a new tourqe are (got a smokin deal on mine used) i would buy it in crome molly because the peice is so big there would be serious weight savings over the steel peice, more so than any other peice. the other stuff would only save a pound or two apeice over the normal steel.
good luck
Old Apr 17, 2006 | 10:38 PM
Thanks for all the info sofakingdom and @ZZKKER. Sorry I didnt fully understand what you were saying before @ZZKKER. I pulled my T-5 out over the weekend and I started looking at my T-56 and I think Im in a little over my head.. So you guys are gonna have to bear with me.. I can understand why you'd want to go for chrome moly over mild steel (for saving weight) but I've ALWAYS hear about guys breaking their chrome moly suspension pieces on the street.. Meaning chrome moly=track only. Granted this is what I remember reading here on TGO.. a long long time ago. I used to be be MORE active on this board...times change and so do priorities..
Dan
Old Apr 18, 2006 | 05:34 PM
@ZZKKER's Avatar
i have not heard of anyone that is running the cm torque arm on the street having any issues. you might want to ask steve and see what he would suggest.
if you start with a t-5 car then half your work is already done!. you just need to enlarge your hole that the tranny pokes up through.
any questions feel free to ask.
good luck
Old Apr 18, 2006 | 07:15 PM
You're talking about where the shifter goes right??
Dan
Old Apr 18, 2006 | 10:33 PM
@ZZKKER's Avatar
yea. its pretty easy.
good luck
Old Apr 19, 2006 | 03:10 PM
so its been a while since I read up on chrome moly vs. mild steel. So i surfed through tgo to figure out if I wanted chrome moly or not. No offense to you @ZZKKER but Im gonna go with mild steel because its 100 bucks cheaper, Im not real worried about saving weight (maybe down the road I'll kick myself in the *** for saying that), and the whole thing about chrome moly breaking (vs. mild steel bending) really is the deciding factor. Im gonna contact Spohn before I place my order just to make sure I'm making the right choice. Thanks for all your help guys.. I'll update this thread when progress is made...
Dan
Old Apr 19, 2006 | 06:01 PM
@ZZKKER's Avatar
non taken. i can understand the money point. parts are not cheap, especially quality ones like spohn sells.
good luck
CarGuyDennis
137
Dec 6, 2016 11:02 PM
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Irocguy01
Sep 28, 2015 02:03 PM
Dialed_In
Aug 20, 2015 01:45 PM
