torque arm needed with ladder bars?
Car: 84 Camaro
Transmission: dont have one yet
Axle/Gears: 3.42 spool on the way
im putting in ladder bars and coilovers on my 84. do i still need the torque arm with this setup?
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
no you wont need it the set up in the car is just as good with upgrades. unless you are changing rears to something like a 12 bolt or 9" or going to tub the car for racing . plus you wont have to cut up the floor.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Ladder bars will eliminate the torque arm and LCA but you still need the panhard bar or a diagonal link for the ladder bars.
I have ladder bars under my car and I needed to modify the floor to get them to fit. The floor pan on a third gen is lower than the diff. The ladder bars are roughly the same height as the diff.
You won't like ladder bars for the street. They'll give a noisy, rough ride. The front heim joints will also need to be changed every few years from street use depending how much mileage you put on the car.
Your little 10 bolt won't last long if you're putting enough power down to need ladder bars.
Car: 84 Camaro
ehh the only real street time my cars gonna see is to work once a week and thats only 1 mile round trip. and eventually ill need to get a 12 bolt or something but it wont have that kind of power for the first season. but hey i figured if im puttin in a cage ill do the suspension too
Car: '88 IROC-Z medium orange metallic
ladder bars, but you've still got a 10 bolt. May I ask why the ladder bars if you're not making enough power to snap a 7.5"? Plenty of guys deep into the 9's with the stock style 3-link setup.
Car: 87 IROC L98
I had a Spohn torque arm and some tubular LCA/panhard bar. The only reason I put ladder bars in my car is that I installed a junkyard 9" diff and it was the easiest way to install it.
Since you're staying with your 7.5" 10 bolt, I wouldn't bother installing ladder bars at this time.
Car: 87 IROC L98
It's an older design and for a 700R4 with a slight modification for a TH350. I don't think you would want to pay the shipping from Canada. You would probably get a better deal buying one from Spohn.
Car: 84 Camaro
1. theyre free
2. eventually im going to get the car into the 10s
3. i need something to do while im saving money to finish my motor
Car: 87 IROC L98
Hang onto the ladder bars until you can get a 9" or 12 bolt housing to use. You won't need a bolt in housing if you want to use the ladder bars.
Run what you have for now. If you break the 10 bolt, it will be time to upgrade to a better diff and you won't have to do the suspension twice.
I ran my aftermarket 3 link system into the low 11's before swapping diffs. I only installed a 9" when I also went with a transbrake in the tranny. I didn't think the tiny 10 bolt could have taken more than one hit off the transbrake.
Engine: 350,289
thats what i am doing till i get my 496 stroker built. i will switch over to my ladder bars. right now i am run what is in my sig. hope everything holds up. i have a ladder bar kit and the 9" all ready. the way i look at it im going to run it till it breaks.
Car: 85 Z28
Engine: GM crate ZZ4 w/ fast burn heads
Transmission: TH350
i'm currently setting up a 9" for my Z28 and i was wondering what type of traction/ lift bars or what not you all prefer, i am looking at doing away with the torque arm...
1. theyre free
