Help with Wheels on a 9 bolt??
Old May 4, 2006 | 04:31 PM
fast112's Avatar
right now i have 16" wheels on my 89 Iroc-z, it has the 9 bolt rear with disc brakes, which 15" wheels would work to clear the disk brakes? looking to run slicks on the back but need a wheel that'll work, any help would be appreciated, thanks.
Old May 5, 2006 | 11:52 AM
Shagwell's Avatar
Car: projects.......
If it has the later, PBR rear discs, then very few 15's will fit. I think weld makes like 3 wheels that will clear.
- How fast you looking to run? You'd be suprised at what you can get out of drag radials...many times dr cars are faster than cars on slicks.
- also, you can get 16" slicks to fit your factory wheels.
Old May 6, 2006 | 12:14 PM
fast112's Avatar
yea but theres very few slicks that i can find, i was looking to break into 13's with the car it runs about a 14.0 right now on street tires, was looking into mickeythompson et street radials.
Old May 6, 2006 | 11:02 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
15" z28 wheels fit. you can have them widened, or you can mount a 275 width tire on there. my freind had them on his gn, and they hooked great.
Old May 6, 2006 | 11:20 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
I have the Z28 15" rims on my 87 with a 9 bolt rear disc. But the brakes might be diffrent between the years. Adam :-)
Old May 6, 2006 | 11:23 PM
@ZZKKER's Avatar
they are different but they still fit over the new brakes
Old May 7, 2006 | 12:14 AM
Well if that's the case. I also had a set of 89 15" IROC rims on the car also. Adam :-)
Old May 7, 2006 | 11:15 AM
@ZZKKER's Avatar
i do not know if the 15" iroc's will clear. i know the z28's will because i mounted a set on the rear of my 89 just to see. i would bet the 15" irocs would clear, but check the clearance before you drive it.
also, anyone know the weight of the 15" iroc compared to the 15" z28? i would bet the z28 wheel is lighter.
Old May 7, 2006 | 02:09 PM
fast112's Avatar
does anyone know the dimensions of those z28 or iroc 15's? so i can find an aftermarket rim thats possibly a little wider? thanks for all the info
Old May 7, 2006 | 05:14 PM
brutalform's Avatar
These are 15x8.5 convos, with a 27 tall ET Street. Fits with the discs no problems.
Old May 7, 2006 | 05:40 PM
@ZZKKER's Avatar
what is the backspacing and offset those for future reference?
those wheels look great btw!
thanks
anthony
Old May 7, 2006 | 06:13 PM
brutalform's Avatar
Thank you. The B/S is 5"... Oh and I found another pic of the rear disc, from the inside of the wheel. Not a real good shot, but it shows that they clear the rims.
Old May 7, 2006 | 08:44 PM
fast112's Avatar
yea those do look great, and that really helps because i know now what size wheel and tire i can run without guessing, thanks for the pic really appreciate it.
Old May 7, 2006 | 11:48 PM
@ZZKKER's Avatar
thats a tight fit, thanks for the info.
Old May 8, 2006 | 11:46 AM
Shagwell's Avatar
you don't need slicks to run 13's......255/50/16 drag radial's on your factory wheels would do more than enough. Hell I'm running 11's on 17" DR's....they're a bit wider though.... - Anyhow, plenty of people running WAY faster than 13's, hooking really hard on street tires.
Old Jun 20, 2006 | 03:33 PM
fast112's Avatar
will stock 15" iroc wheels fit over the brakes or not? because i know a few people that have some laying around that i could probably get for free to throw drag radials on for the track.
Old Jun 21, 2006 | 02:23 AM
CrazyHawaiian's Avatar
Car: too many ...
I have an 89 IROC-Z with the B/W 9 bolt rearend with PBR disc brakes. The stock 15x7 wheels from both the RS and IROC-Z models fit with no rubbing. I'm only talking about the wheels though, tire rubbing might be a different story (depending on what tire you use and the suspension).
Old Jun 21, 2006 | 12:12 PM
Shagwell's Avatar
I still wouldn't want to be on slicks only running in the 13's.....
Old Jun 21, 2006 | 01:00 PM
fast112's Avatar
well i got the slicks for free, and they're in good shape and should fit under the car nicely, so if its free i might as well mount em up and get a better time than on my streets, i went down to the track and couldn't get out of the 15's all night because of the car not hooking up at all.
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
Dialed_In
Aug 20, 2015 01:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
