15inchers an big tires
Car: 1985 Iroc Z
Engine: 383 carbed
Transmission: Th 400 tci super street
Axle/Gears: 3:42 9 Bolt
alright boys i need some help i need some 15inch wheels with the biggest drag radials i can throw at them.. i want the tires an rims to stick out the back.. wats the best rim an tire combo to do this?.. also the best lookin rim
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Best looking rim is a personal preference. My car has Weld Draglites. My truck has American Racing "centerline" look-a-likes.
Doing a few inner fender modifications, you can use a 15x10 rim with 5.5" backspacing. A 28 x 10.5 slick can be made to fit. I have a 29.5 x 10.5 under my car but I also have a bit more fender modifiactions since my axle is positioned back about an inch.
As for a "drag radial" tire, the P325/50R15 can be made to fit but the P275/60R15 would be an easy fit although it only needs an 8" rim.
If you want the tires to "stick out", get a 10" rim with 3.5" backspace.
Car: 1985 Iroc Z
Engine: 383 carbed
alil more info for tires.. its gonna be a street strip combo deal.. im gonna get QQ plates so im only gonna be drivin it once in a while
Car: 87 IROC L98
Your factory tires are 26" tall. You want to stuff as tall a tire as possible under the fenders because it gives a bigger footprint from front to rear however a taller tire also needs deeper gears. Tire height and gear size will depend on how much power the engine makes and at what rpm, type of tranny, converter stall speed if an automatic transmission.
There's stock eliminator cars running low 10's on a 30 x 9" slick so big fat tires are not always needed.
Car: 84 firebird
Engine: 434ci
Transmission: turbo 400 3500 stall transbrake
Axle/Gears: 10 bolt 4.10 spool'd
on my car i have centerline auto drags with a five inch backspace and a 325/50/15 bfg drag radial the car does hook hard with stock suspention just some minor work was done to the inner wells
Are you after looks or performance?
- 275/60's fit about the best w/o major work. The 325's would go, but it'd take some work to make 'em fit and look right.
Car: 87 IROC L98
I currently have 29.5 x 10.5 slicks but I'm seriously considering back halfing the car after the 2006 season and stuffing 32 x 14 radials or 32 x 16's bias under the fenders. The bigger contact patch will help me with traction off the line. If all goes well, I should be at least in the high 9's at altitude this year. 2 tires are only $600 and normally last one season.
There have been cars running 8's with a 10.5" tire so big tires are usually only for looks with a low HP car.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
unneccesarily big tires look goofy. pick a tire size that matches your car and forget about what "looks" good. A bad car on a small tire looks way better to me than a slow car on a big tire... I might be silly though. I run a 27x10.5" QTP on a 15x8 5.5"BS rim it fits perfectly, no need to modify the inner fender, and it tucks in under the car. Next set I buy will be 27x11.5" QTP and even those will tuck under the car.
Car: '88 IROC-Z medium orange metallic
I am using a pair of 275/50/15's on stock 15x7 wheels. Works great but looks like a@@. They don't stick out but they're 28" tall so they fill the wells up
If it wasn't a race car they'd be long gone.
If it wasn't a race car they'd be long gone. Thread
84 TA NV
Sep 6, 2015 08:02 PM
