Moog and Monroe
Old May 2, 2006 | 03:14 PM
merlot-fro's Avatar
Car: 86 Trans Am
Moog and Monroe
my front end bounces. its time to replace the springs and shocks
I think ill get the Moog springs and Monroe Sensa tracks (I don't like the things I hear about KYB)
does this sound like a decent spring/shock combo?
Old May 2, 2006 | 10:00 PM
rodrigo diaz's Avatar
Car: 92 rs
Engine: 5.0
Transmission: 5 speeds
monroes are much worse i had both and the kyb are better but not the best either
Old May 2, 2006 | 10:27 PM
Stevo's Avatar
Car: Pair of 92 Z28s
i like kyb more...moog springs are good.
Old May 2, 2006 | 11:03 PM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
So
What's wrong with monroe? Personally I used Lakewood's I was just curious.
Old May 3, 2006 | 11:20 AM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Monroe will be fine if you want STOCK ride, if you want anything performance wise, go for Bilstiens, Koni's or tokiko(or however the hell they spell it). KYB's fall into the same catagory as Monroe, STOCK ride. I love my Prokit/bilstien Combo.
Old May 3, 2006 | 12:23 PM
Shagwell's Avatar
Car: projects.......
the KYB's are stiffer than Monroe's, but not by a lot. The monroe's are built for factory spec, that's what they're designed for. - Moog springs/bushings/linkage/etc.... are good though. The springs are gonna be factory spec, but you can easily go with the WS6 stuff...
Old May 3, 2006 | 09:39 PM
92MaroRS's Avatar
right the KYB's are stiffer, but they are not stiff enough to take them out of the stock ride catagory.
Old May 4, 2006 | 12:04 PM
Shagwell's Avatar
...the KYB's are stiffer, but they are not stiff enough to take them out of the stock ride catagory.
agreed. But I'd still take them over Monroes'...
Old May 4, 2006 | 01:42 PM
92MaroRS's Avatar
eh, the Sensa-Trac's are fine, as are the Reflex, just don't get cheap and buy the Gas-matic's. otherwise i'd have no problem putting Monroe's on a car i just needed Factory ride.
Old May 23, 2006 | 01:20 AM
merlot-fro's Avatar
Car: 86 Trans Am
thanks for the feed back,
the springs and struts are being put on all 4 corners. I'm also having some energy suspension polyrothene bushings and a wonder bar put in. The same shop is also going to pop in one of those nifty lil "Posi units" i hear so much about on here.
Old May 23, 2006 | 10:01 AM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
I put sensa-tracs on the front and kybs on the rear of my Iroc, it was a ton of improvement over the leaky ones on there. I just didn't have the money to go all out. You should also do the front strut mounts they made a world of difference too.
Old May 23, 2006 | 10:15 AM
Deimos140's Avatar
Car: 91
Hmm
So are you speaking of the sensatrac's or the the reflex's. Cuz the reflex's should be more stiff than the KYB's.
Old May 23, 2006 | 12:02 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I put the moog 5665/5662's along with the kyb's on my car about a year ago. The springs are great, the struts were okay for a short while but are now not up to the task of controling the front springs. The shocks still seem to be okay. I would bite the bullet and get some koni yellows for the front, I wish I had when I did it all the first time.
Old May 23, 2006 | 12:34 PM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
IMO I think that KYB's feel much stiffer than Monroe. I know KYB is not close to Koni or Bilstein...but I think for the money they are much better than Monroe.
Old May 24, 2006 | 10:46 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Axle/Gears: 3:85
reflex's are made for trucks and suvs not cars.....
Old May 25, 2006 | 02:35 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Good point!! All too often overlooked.
Old May 26, 2006 | 06:04 PM
70gmc's Avatar
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
So if neither of these two are that good. what is the best aftermarket strut and lowering spirings?
Old May 29, 2006 | 12:33 AM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
on the wonderbar. granted, 1 of my swaybar bolts were a little loose. But after the install it tightened things up wonderfully for me. I used to have problems with vibration and squealing on tight turns. It felt like the tires were pointed at two different angles. No more. Also, going over bumps (at the same time and at a diagonal) feels alot tighter. This is all aside from the improved handling with all stock front shocks (Gabriels) and front springs (maybe the original 231k ws6 springs? they're probably just as low as a prokit now lol).
Old May 29, 2006 | 02:05 AM
jsel's Avatar
Car: 1989 iroc conv
Engine: L03 TBI
Transmission: 700R4 soon to t5 from hawks
rebuilt front end this winter used moog,blistine and kyb also used energy suspension bushing on the lower control arm very pleased with the resaults.
customblackbird
Aug 15, 2021 10:16 PM
87v6Bird
Jul 1, 2018 04:12 PM
starfinder
Oct 25, 2015 10:40 AM
loud91rs
Oct 5, 2015 10:05 PM
TA8487
Aug 11, 2015 09:02 PM
