GTA wheel spacers
Old May 10, 2006 | 11:14 AM
o2b18's Avatar
Car: 91 Camaro RS
Engine: L03 chip, airfilter,dual exhaust..m
Transmission: 5-spd
GTA wheel spacers
I need a 1/8" spacer to mount GTA rims on my 91 RS (drum brakes)
AutoZone sells a universal 3/16" spacer. Would that work ok? I'm running 245 tires, I'd think they'd be ok but thought I'd ask first.
Old May 10, 2006 | 11:46 AM
Shagwell's Avatar
Car: projects.......
...should be able to run w/o the spacers.........
Old May 10, 2006 | 12:01 PM
o2b18's Avatar
Car: 91 Camaro RS
Transmission: 5-spd
The tire is rubbing up against the rubber snubber (?) and the bracket that holds that to underbody. Why did GM make a .125 spacer if it wasn't needed? I suppose this could be hammered in?
Old May 10, 2006 | 12:37 PM
Shagwell's Avatar
...hummmm. I've never seen a factory vehicle with spacers. And the disc rear is the same width as a drum rear.
- anyhow, as long as the studs come through the wheel far enough to PROPERLY hold a lug on, then go with the parts store units. - Also, it may only rub at full extension(as in car jacked up, tires hanging)
Old May 10, 2006 | 12:48 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
spacers
I used them on my 92 firebird. They are used on car with drums brakes (iron drums) Came on T/A with 16 inch rims.
The aluminum drums are a different thickness. There was a post on these a while back. Do the search. Can probably answer alll your questions.
Old May 10, 2006 | 01:08 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Are the stock ones really 1/8"? I have them laying around here some place from my old drum rear. Didn't think they were that thickness.
From what I've seen I think you should still have proper lug engagement. Buy them, slap them on and take a look for yourself. If they don't work, take them back.
Old May 10, 2006 | 01:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
GM spacers can be purchased from the following site:
http://www.moderndaymuscle.com/inc/s...acers&n=844381
JamesC
Old May 14, 2006 | 10:00 AM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
It's possible that all the 16" factory rims required spacers. I have 2 IROCs and both sets of wheels are labeled "front" and "rear" and the rears had spacers between the rotor and the wheel. I bought a wrecked 88 Formula with 16" WS6 wheels and drum brakes and it also had the same spacers between the drum and the rear wheels. The WS6 16" wheels are also labeled "front" and "rear".
The offset is different from front to rear. I might be wrong but it seems like with all the engineering talent GM has they'd have been able to get the offset right in the first place to use 245X50 16" tires and not require spacers to keep the tires from rubbing.
Old May 15, 2006 | 03:26 PM
Mr. TurboTA's Avatar
Maybe it's just me, but I have never seen spacers on GTAs or Trans Ams with the Diamond Spoke wheels. At least, not on any cars that I pulled the wheels off of.
My 20th TTA never had spacers, and I bought that car new.
I have installed the Diamond Spoke wheels on other Firebirds, and never had to use spacers. Either with the "dimple" wheels or "non-dimple" wheels.
Anyone else?
George
Old May 15, 2006 | 04:49 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
My TA with the crosslace 16's had the spacers in the back. I had always thought it was because of the drums.
My old 87 formula with rear discs had no spacers and obviously had the stock convex 16" wheels.
And are fenderwells/suspension was not designed around a 245/50r16 tire, it was probably closer designed to the original 205/65 or whatever came on the 15's in 82.
Amillionoh7
May 24, 2020 08:01 AM
deracer
Apr 11, 2016 12:04 AM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
kah992
Aug 19, 2015 02:55 PM
