Installed Wonder Bar
Old May 11, 2006 | 12:17 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
to slow305 I got a factory IROC wonderbar. I had to let everybody know who doesn't have one what a difference it makes. It tracks straight (no wandering in lane) and is so much more accurate in the corners. Real easy install too. 4 bolts out, install wonderbar inbetween sway bar mounts and frame, 4 bolts in.
Old May 11, 2006 | 01:43 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
WOW....That simple steering support brace did wonders to your car's handling I wonder (bar) what real suspension parts would do for you??
Old May 11, 2006 | 01:57 PM
krisb410's Avatar
Well I got the 34mm Hollow front sway bar and 21mm rear sway bar now. I would like the 36mm front and 23mm rear ones, as well as the 2.14 ratio steering box. Eventually I will get tubular LCAs and panhard. SFCs and Upper strut tower brace as well.
What order should I upgrade. The reason I got the wonder bar 1st is because it's cheap and super easy to install.
Oh, the previous owner put "springs" on the car. I don't know what brand they are but the car sits noticably lower then other camaros.
Old May 11, 2006 | 02:55 PM
Stevo's Avatar
Car: Pair of 92 Z28s
sub-frame connectors...only if you can find someone to install them though
I picked up WS6 sway bars from a member here for i think $40? They normally go anywere from $50-100. Id do that next as its still pretty cheap. Got the iroc steering box for $50 from another member/friend here.
All my tubular suspension pieces were a lot cheaper because they were used(hardly) but i saved at least a combination of over $100 on going that route.
my BMR STB is on the way...better get here before thursday though. Ill post my review on that whenever its on.
Old May 11, 2006 | 06:08 PM
Demon355's Avatar
I will be installing a wonderbar along with SFC's, LCA's, LCA brackets and an Adj.Panhard bar. All ordered from UMI. Check them out if you want to get these parts, they're great. Good customer service too. Talk to Ryan.
UMI Performance Inc.
Old Jun 4, 2006 | 08:13 PM
krisb410's Avatar
Well I got the 24mm rear sway painted and installed today. I can tell a big difference. Still waiting fot the front bushings to come in. Should be here tue. so wed. I will install the freshly painted 36mm hollow front sway. I can't wait!
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
overdriv
Aug 20, 2015 03:52 PM
