Will a track bar brace off an 00 fit my 91 z28?
Old May 15, 2006 | 05:03 AM
C6matt's Avatar
Car: 05 C6, 91 z28 Vert, 66 Mustang vert
Engine: Ls2, TPI 350, 289 4bbl
Transmission: T-56, T-5, C4
Axle/Gears: 3.42,3.08,3.73
I need a new track bar brace ...the only ones Ican find are off a 93-02 camaro.. they look the same..does anyone know for a fact if it fits?
Old May 15, 2006 | 07:35 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Are you referring to the panhard bar bracket brace??? The piece of stamped steel that goes from the chassis down to the passenger side bracket that holds the one end of the panhard bar??? If so, then yes I think it does work. I have an 87 TA, and I bought a brand new one of these braces from gmpartsdirect for $8... I just pulled one off my 99 camaro parts car, and it was EXACTLY the same. Down to the little heat sheild screw hole.
So basic answer..as far as I know they are the same.
Justin
Old May 15, 2006 | 08:07 AM
C6matt's Avatar
yeas the panhard bar brace... on gmparts direct it lists for 46 bux... my dealer has it for 45, I can buy one for a 93-02 camaro on ebay for $29 shipped... I just wondered if it was the same, the pic looks the same..
Old May 15, 2006 | 08:13 AM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
It will fit. Listing in G.M. parts catalog shows - Chevy and Pontiac f-body 82-02 part #10019526 "rear axle tie rod bracket brace".
Yes the 2000 part will fit your 1991.
Old May 15, 2006 | 08:35 AM
C6matt's Avatar
thanks for the info!
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
z28addict8490
Aug 7, 2015 08:48 PM
NBrehm
Aug 5, 2015 07:57 PM
