lots of play in steering
Old May 17, 2006 | 04:15 PM
UDLooz's Avatar
I have a lot of play in my steering, with the car off I can roll the wheel at least 1" each way before meeting resistance, which leads me to believe it is the rack. Anybody else have experience with this problem? It is an IROC so the steering should be a lot tighter.
Old May 17, 2006 | 04:47 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Either the pivot on the centerlink is loose or the guts in your steering box is worn out.
I just had the steering box replaced in my Z28 cost me $400 installed.
Old May 19, 2006 | 12:13 PM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Check the rag joint also.
Old May 23, 2006 | 01:14 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Anything else it could be ? Mine's very loose too, I don't expect to be tight as an Iroc box, but yes I have that dang play in it too
Azrael91966669
25
Jun 20, 2017 04:04 AM
deracer
Apr 11, 2016 12:04 AM
backtothe80s
Sep 5, 2015 12:39 AM
SlowAZ28
Aug 31, 2015 07:56 PM
86White_T/A305
Aug 17, 2015 12:16 AM
