stock ride height
Old May 22, 2006 | 03:04 PM
eddie jr's Avatar
stock ride height
Just wondering if those of you with replacment springs (not lowering), could you post a picture of your car so I can get an idea of the factory ride height. I am trying to decide which way to go as I don't know if or how much mine are sagging, but the fronts definitely need replacing. All the pics I came across in searching were lowered cars.
Also if you have measurments from the centre of the axle hub the the fender well (which would eliminate different size tires) that would be helpful too.
thanks.
Old May 22, 2006 | 10:32 PM
eddie jr's Avatar
Nobody with stock replacement springs???
Old May 22, 2006 | 10:44 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Every body is lowered here
Old May 23, 2006 | 12:10 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
These are moog 5665/5662's
Well, the file is too big. Anyone know how to make it smaller?
Old May 23, 2006 | 12:19 PM
eddie jr's Avatar
Not sure, but you could always email it to me at eddiejr@rogers.com
Old May 23, 2006 | 05:40 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
email sent
Old May 23, 2006 | 07:53 PM
eddie jr's Avatar
email sent
thanks, got them! So how old are they? Did the ride get higher from the old ones or is it pretty much the same? And did they have to settle at all?
thanks.
Old May 24, 2006 | 10:34 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
They're about a year old and are taller than the old 16x,xxx mile stockers. I did'nt notice them settling much, if at all. I think I'm gonna cut a half coil off the backs, mabee a little off the fronts depending on how much it raises after aluminum headed 350/t-5 swap.
Old May 28, 2006 | 09:48 PM
eddie jr's Avatar
How much do you figure it is higher than your old ones? Really noticeable or subtle?
I was wondering if you could do me a small favour??.....could you measure from the centre of your centre caps to the fender lip (the metal lip not the plastic up in the wheel well)?? That will give me a concrete # that I can use for comparison. By measuring from the centre of the cap that eliminates tire and wheel size (which mine are different than yours).
thanks.
customblackbird
Aug 15, 2021 10:16 PM
Genopsyde
Oct 7, 2015 08:35 PM
sailtexas186548
Aug 26, 2015 03:32 PM
Linson
Aug 21, 2015 02:12 PM
sreZ28
Aug 14, 2015 07:48 PM
