leaf spring swap?
Old May 30, 2006 | 08:55 PM
snapsmagee2000's Avatar
Car: 91 z28 100kmiles
Transmission: 700r4 hoping to be t-5 soon
Axle/Gears: 3.42 posi
leaf spring swap?
has anyone everthought of putting an s-10 leaf spring setup on a third gen i think it would work and it would be really neat to see done
Old May 30, 2006 | 09:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You couldn't do it without grossly modifying the rear half of the car, and I can't imagine why someone would go through all the trouble for such a horrendous downgrade in performance.
Old May 31, 2006 | 12:01 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
because that my friend is the red neck coming out in him.... wants the *** end lifted to make it look like a white trash car.....
Old May 31, 2006 | 11:38 AM
Shagwell's Avatar
Car: projects.......
I agree with Apeiron. Why would you go through near that much work to down grade your suspension?
Old May 31, 2006 | 12:23 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
There are some good reasons for using leaf springs. It would be cheaper than a four link if you were installing some very wide tires out back, also easier to install a stronger rear axle like a 9inch from a truck. Just line it up and weld the brackets to what's left of your frame rails, sure beats blowing your weakass tenbolt at the track or spending a grand on something like a 12bolt, 9bolt, etc.
What are your reasons for wanting to do this?
Old Jun 1, 2006 | 11:47 AM
Shagwell's Avatar
...ok, so now that you have wider tires, a better axle and less traction/no rear seat and had to completely re-do the rear subframe so that the springs could mount/support the car....what have you gained?
- Not trying to argue, just trying to understand any reason for this. I'm running 315/35 rear tires on 11" wide rear wheels with only slight trimming of the rear bumpstop to fit them. All home-made tq arm suspension and a built 10-bolt, cutting consistent 1.6X 60fts and running 11.7's no problems.
Old Jun 1, 2006 | 09:18 PM
i just thought it would be kinda cool
plus if u want a weekend warrior without the cost just slap a 12bolt and leaf springs in it with traction bars
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
