hooking
Old Jun 4, 2006 | 05:57 PM
jamiehoyts's Avatar
hooking
I need some info on other guys suspension what they used and what kind of 60 fts they are getting changed from et streets to mickey radials not happy.went from 1.62 to 1.74
[QUOTE=jamiehoyts]I need some info on other guys suspension what they used and what kind of 60 fts they are getting changed from et streets to mickey radials not happy.went from 1.62 to 1.74.
Old Jun 4, 2006 | 07:18 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
lakewood LCA's, Spohn relocation brackets, Spohn TH400 torque arm, stock shocks/springs. 28" ET Radials and 3.42's 1.68 60'
Old Jun 4, 2006 | 07:36 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
well you switched from a slick to a drag radial. the slick typically is better for the track for 60' times. You bought a tire that you can drive to the track and back home. I would have expected the tires to not hook as well either. did you try different pressures in the drag radials?
Old Jun 4, 2006 | 07:41 PM
brutalform's Avatar
Jamie, are you running a stick shift trans?
Old Jun 4, 2006 | 07:50 PM
jamiehoyts's Avatar
hooking
I have purchased some koni spa1 for front also moroso springs.just need some help on rear i have only comp engineering 3 way adj and boxed control arms called spohn about torque arm said it would not work with super comp headers and mufflex y pipe but his stock mounted one would dont like that set up off the rear transmission with poly mount.dont now where to go from here.
No it is automatic with vigilante 2800 converter
Old Jun 4, 2006 | 07:53 PM
brutalform's Avatar
Do you have a stick, or auto?
Ok I see you added the answer in your edit.
Old Jun 4, 2006 | 07:57 PM
jamiehoyts's Avatar
hooking
Bare with me this computer thing not real good at the car has automatic with vigilante 2880 converter
Old Jun 4, 2006 | 08:02 PM
brutalform's Avatar
Try playing with the pressure, launch technique, etc. Im sure you will get them to hook. There has been problems with those tires in manual equipped cars, but, I dont recall anyone having issues with autos. The same thing happened to me when I was doing 1.68s with my BFG radials, then they went up to 1.75s with my ET Streets. After playing around, the 60s improved.
If you do not have relocation brackets, I would install them.
I have Spohn brackets, SFCs, Drag shocks (rear only), "boxed" LCAs, and a tubular adjustable panhard, and I 60' at 1.54s, with ET Streets.
Welcome to TGO, you'll get better at the computer thing...dont worry.
Old Jun 4, 2006 | 08:03 PM
jamiehoyts's Avatar
hooking
Yes iwas running between 15-20 lbs
forgot to tell you that Iam spraying it with 150 nitrous do have nos delay box but was hoping to get it to hook without delay
Old Jun 4, 2006 | 08:22 PM
Dialed_In's Avatar
Holy lack of punctuation, Batman!!!
Old Jun 5, 2006 | 11:56 AM
Shagwell's Avatar
Car: projects.......
best of 1.66, consistent 1.66-1.69. - 315/35 nitto dr's, homemade tq arm, lca's, relocates, and in-floor frame(set-up is beyond sfc's), 8-point roll cage, 5-speed trans, 5k side-step.
play with the pressure and launch rpm. I also agree on the lca relocates, but with previous 1.6X range, lca angle probably isn't too bad.
- Many street cars have gone faster on the radial tires than slicks. I've even seen better 60fts. - it all comes down the the suspension tune-up.
definition of "street" - factory type suspension, non-back-halfed cars...for this post anyway...
Old Sep 11, 2006 | 10:53 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I know this is an old post but I made my spohn torque arm work with the mufflex Y-pipe. My best 60' time is 1.47 with a 6.72@106 mph 1/8th. Here is what I did. I decided not to use the spohn crossmember. I then modified the factory crossmember to mount to the front of the torque arm. I made a mount to to accept the front of the torque arm and welded it on. I don't have pics but it works perfect. Not as beefy as the spohn crossmember but still works.
Old Sep 12, 2006 | 12:06 PM
brutalform's Avatar
Hey 94, do you have any pics of that set up. I use the Mufflex 4", and can not use the Spohn arm, but would like to....Thanks!
Old Sep 12, 2006 | 12:54 PM
Shagwell's Avatar
94-6spd - good idea. Yes, it wouldn't be as beefy, but it'd work good(well...obviously it does) - I'd probably do a little bracing on it though, maybe some small angle or some small round tube welded across the bottom to strenghten it a bit.
jamiehoyts - anything new? - I'd try uping the psi to around 25. Radials don't squat like slicks, so the lower pressure just causes you to loose contact patch.
Old Sep 12, 2006 | 01:47 PM
brutalform's Avatar
94, Sorry man, I just re-read your post, as you said you did not have any pics.
Z28/ZR1
Oct 23, 2015 01:04 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
