pro star question
Old Jun 16, 2006 | 07:15 PM
casebaseball205's Avatar
pro star question
lookin at doin a 15x8 back and 15x6 front. is my ride quaility going to be ****? and im doing a sportline drop by the way
Old Jun 16, 2006 | 07:41 PM
EvilCartman's Avatar
Car: '82 Z28
Why would Pro Stars affect ride quality? Biggest change in ride is going to be due to the drop. I could understand if you were going to 17's or 18's since the smaller sidewall would give a little harsher ride but with 15's and all that sidewall, they'll soak up a bit more of the bumps.
Old Jun 16, 2006 | 08:04 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
why are you doing drag wheels with handling springs? your gonna have a car that doesn't handle well cause the wheels aren't designed for it, nor is the tires made for the 15" wheels and it won't drag race well cause the car will not have any kind of weight transfer...so getting it hooked up is gonna be a bear.
other than that, you won't notice a difference in ride quality.
Old Jun 16, 2006 | 08:27 PM
brutalform's Avatar
I do not know your intentions with your car, but the drag race rims are not to be used in autocross. Centerline for one, warns against it with their ConvoPros. Just my
Old Jun 16, 2006 | 09:38 PM
car is a summer car. not dragging. will be more of a cruiser. i just like the look like on tuneports maro. think it looks nice. not bad price either
Old Jun 19, 2006 | 12:31 PM
Shagwell's Avatar
Car: projects.......
the wheels won't change ride quality. The springs will, and depending on your tire size, that could also. As stated, 15's with a common tire height will have more sidewall flex, thus ride "better" but do not corner as well. The stiffer springs will not give as much, there fore ride "worse".
I'm cutting pretty good 60fts on sportlines, but my suspension has a few mods. If you're just going for the look, then coil cut it and keep your stock springs.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
