abnorable wear on driver side front tire
Old Jun 25, 2006 | 12:40 AM
krogmister16's Avatar
Car: 88 firebird formula
Engine: 305 tpi
Transmission: 700r4 with shift kit
Axle/Gears: 3.73 with eaton locking diff
i just some used tires a while back. ive put about 100-200 miles on the front tires. my drivers side front tire is wearing really wierd. the outside has no where and the inside is worn to all the way. and i looked at the passenger side and there is no where at all. does anyone know my problem?
Old Jun 25, 2006 | 12:43 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
alignment maybe? im going to get mine aligned monday...
Old Jun 26, 2006 | 10:32 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
Sounds like you have excessive negative camber on the left front. Does it pull to the right?
Old Jun 27, 2006 | 12:47 AM
CrazyHawaiian's Avatar
Car: too many ...
Its one of two things, either the tires or the car. When you use used tires you have to really check them out. Sometimes its not easy to spot uneven wear patterns. So if the tire was used on a car with a problem that caused uneven wear, and then you go put that tire on your car, you'll also experience odd wear characteristics. The tire could also not be balanced properly causing odd wear. The other possibility is its your car. Our cars are old these days, suspension components wear out. In the front suspension, when some part wear (most commonly the balljoints) they can cause alignment issues. So if this were the case then its actually two problems, worn suspension parts, and a bad alignment. In your situation I would have the alignment checked. Whoever checks it will be able to determine if its good or bad, and if its bad, should be able to determine why.
kyleb24
Aug 15, 2015 08:24 AM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
