Would 275s fit front and 315s rear?
Old Jun 25, 2006 | 10:45 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Would ZR1 with 275s front fit without rubbing with spacers? If so what spacers I need?
As for the back I have a 4th gen rear. Would 315s fit?
Old Jun 25, 2006 | 11:37 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
2" and 2.25" spacers (I had both sizes, now using just the 2") on my front with ZR1's (both available offsets) rub on my car.
315's usually require a hammer and fender rolling.
Old Jun 26, 2006 | 01:25 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
honeslty, do a search - this has been covered a bunch of times, and i know for a fact that there is great thread that i posted a bunch of great info in...
Old Jun 26, 2006 | 01:44 PM
crrllmich's Avatar
Engine: L03, LS1
I searched "315 tire" and dint get anything.
Old Jun 26, 2006 | 05:26 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Moving to the correct forum per the sticky at the top of this forum..
Old Jun 26, 2006 | 08:09 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
I have 315's in back on a 4th gen rear end and everything fits fine, no hammer needed.
Old Jun 26, 2006 | 08:21 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
that's because the 4th gen rear makes up for the offset difference.
Old Jun 27, 2006 | 01:11 AM
CrazyHawaiian's Avatar
Car: too many ...
What springs are you using? Ride height plays a big role into clearance and rubbing. The condition of the struts/shocks is also important, you want to avoid excessive suspension travel.
Old Jun 27, 2006 | 10:46 AM
fb305svs's Avatar
ok... now that i have more time... I did a search and came up with the following info in adidition to what already i have experianced.
a) you having a camaro makes a huge difference. Firebirds between the sheetmetal are 2" total narrower in the body - which make tucking the wheels in even more difficult in the back.
b) The fourthgen rear comes 2" wider per side - this could be a potential problem. Make sure you get at least the 50mm offset 17x11's... the 36's will stick out.
c) I don't think you'll have to do much clearencing, but if ya do, all it takes is a 2 1/2 lbs sledge, and some por 15 to paint the well.
d) front is easy as pie - 2 - 2 1/4" adaptor up front... I do get some rubbing when i go to lock, i would have been better off with the 2 1/4" spacers - they still would tuck under the fender fine.
Basically, 17x11's can be done no problem, but for you, because you have a wider rear, you are going to possibly need a custom offset wheel to get the best "tuck" possible... there is nothing worse than a set of wheels sicking out
Old Jun 27, 2006 | 11:18 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Why?
Old Jun 27, 2006 | 12:08 PM
Shagwell's Avatar
Car: projects.......
- my 91z was exactly the same as my GTA. Even had the GTA wheels on the Z for a while, zero difference in offset or fender clearance.
- I'm currently running 17x11 with a 8" bs, 4th gen rear, 315/35/17's on the back. Sits square with the wheel well. Do a search under my name, there's plenty of pics floating around.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
