replacing bushings before alignment
Old Jun 26, 2006 | 01:19 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
i've already installed a fresh set of poly sway bar end links in the front end of my 89' firebird formula, just wondering what other cheap things i should replace before getting a GREATLY needed alignment done on the car. thanks!
Old Jun 27, 2006 | 01:55 AM
CrazyHawaiian's Avatar
Car: too many ...
I would check to make sure the balljoints and a-arm bushings are good. They are relatively cheap but taking the a-arm off to have them replaced takes some time. If they check out good then you probably don't need to replace them. Another thing I would check is the condition of the struts, if they are blown I would replace em before getting the alignment (or else you'll just have to align again later on down the road). One cheap thing you can do though, those Coleman Racing solid tie rod adjusters to replace the crappy stock ones, they are like $20 for the set, but like balljoints and a-arm bushings, takes some time to install them.
Old Jun 27, 2006 | 03:15 AM
bigchief's Avatar
ok man, will do. thanks for the advice
Old Jun 27, 2006 | 08:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Many places also have a lifetime alignment deal. I just got one at Firestone, $119 (twice as much as most other single alignment jobs) - and they will realign every 5000 miles as long as I own the car! Get one of these, and do as many suspension mods as you like as you get the cash, and just keep taking it back for free realignment!
Old Jun 27, 2006 | 08:23 PM
bigchief's Avatar
wow man really! i think im gonna do that. thanks a lot!
Orr89RocZ
Apr 25, 2016 08:28 AM
g.l.mos
Aug 22, 2015 12:02 AM
383backinblack
Aug 15, 2015 06:36 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
NBrehm
Aug 5, 2015 07:57 PM
