36mm sway bar body bushings
Old Jun 30, 2006 | 06:14 PM
laiky's Avatar
i have a 36mm hollow bar i would like to install. can anyone tell me where to get the body bushings in urethane that doesn't squeak or a greasable version? i remember reading about some here that were being moddified
Old Jun 30, 2006 | 06:18 PM
DRR's Avatar
DRR
Car: Nothing stock- I screw with everyth
Engine: Hook&Ladder #8
Transmission: Morris Code
Axle/Gears: AxleROse CD Collection & Scuba Gear
Top-DownSolutions.com
Old Jul 20, 2006 | 04:27 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
spohn also has them. Energy suspensions doesn't list any in their catalogs
Old Jul 21, 2006 | 04:47 AM
83 Crossfire TA's Avatar
They don’t have to be EXACTLY the same size, as a matter of fact, every set of factory bushings that I’ve ever pulled off a 36mm sway bar were labeled 34mm. This stuff has a tendency to cold flow and take the shape of whatever it’s pressed up against when you bolt it up.
Old Jul 21, 2006 | 07:06 AM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Guldstrand sells polygraphite bushings for a 36mm bar. They only make noise when it is really cold out.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
