Spohn A - Arm Bushings
Old Jul 10, 2006 | 11:39 PM
1989GTABlown632's Avatar
Car: 1989 Pontiac Firebird Trans-Am GTA
Engine: Blown 632 CID with Nitrous
Transmission: TH400
Axle/Gears: 4:10
Hey guys, been pulling my hair out on this one, who ever thought it would be such a pain to find a set of bushings. I just bought set of Spohn tubular A - arms for my T/A black powder coated with spring pockets. Now the cars a show car and its all black I re-did the entire car with all black poly bushings. Now I just bought these beautiful a arms and they have red poly bushings in them. My questions is does anyone know a cross referance number to get a set threw energy, prothane or other company that makes black poly bushings. I called spohn and they said they only carry these bushings in red. Ive searched TGO with no luck I believe the LCA and A Arms use that same size bushing. Also a note the one I pulled out has the number 61217 written on it but the only thing thats matches that number is Prothane and they show that PN as being an 99 - 04 F 250 Superduty Track Arm Mount. If anyone has any info I would appreciate it Thanks.
Old Jul 11, 2006 | 05:01 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Yep they only come in red. The one for the a-arm is custom made for Steve. So you're not going to find anything off the shelf for them.
Old Jul 11, 2006 | 05:39 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Nothing a Sharpie can't fix.
Seriously, try it. They're the A-arm bushings, are people going to be looking that close?
Old Jul 11, 2006 | 09:13 PM
Transmission: TH400
Axle/Gears: 4:10
Thanks for the replies guys. Its funny you said that I just took a sharpie to the bushing right before I loged on and it actuall worked out good.
Old Jul 20, 2006 | 04:07 PM
Transmission: TH400
Axle/Gears: 4:10
Hey just wanted to let everyone know, I did a little more research into finding a comparable poly bushing in black for the spohn A arms. I found one at this URL http://www.mountainoffroad.com/catalog/UnivBushAssy/uba.htm part number BA200. They are the same size except the bolt and sleeve assembly "C" is 3/4 instead of 7/8 and the bushing "D" is 1 1/4 long verses the rears which are 5/8 and the fronts that are 1 1/8. See attached pic for a detailed pictorial. All you need to do is trim them to length and your good to go. Ill get some pics of the arms and bushings this weekend.
Old Jul 23, 2006 | 10:00 PM
Transmission: TH400
Axle/Gears: 4:10
Well I got a couple of pics of the new Spohn A-Arms and black poly bushings. I gonna install them as soon as I get back from my trip. Consequently I now have a new set of bushings for sale if anyone needs them. https://www.thirdgen.org/forums/engi...ings-sale.html
TTYAL Later
Old Jul 23, 2006 | 10:01 PM
Transmission: TH400
Axle/Gears: 4:10
Oops forgot the PICS
Attached Thumbnails Spohn A - Arm Bushings-aarms.jpg   Spohn A - Arm Bushings-aarms2.jpg   Spohn A - Arm Bushings-aarms3.jpg
Old Jul 24, 2006 | 04:57 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Just make sure when you install them, you use put a coat of grease on the bushings.
The onl downfall to the ones that you got, is that they are missing the flutes for the grease to come out and lube the side of the poly bushings. Nice find man.
Old Jul 24, 2006 | 02:09 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I saw this and it gave me an idea. How wide are the rear LCA bushings? ~3"
Old Jul 24, 2006 | 03:12 PM
Transmission: TH400
Axle/Gears: 4:10
KAT - Thanks I ordered a tube from spohn wed so it will be here when I get back though its funny when I first ordered the first set from these guys I ordered Kit BA175 which stated 1 3/4 bushings but I didn’t allow for the tubing size anyway to make a long story short these are the next size down and they did have the flutes but for some reason the next size up didn’t have them. Ill call and find out on a plus note though the bolt is 9/16 instead of 1/2 so its heavier duty.
Scooter - I’m not sure which one you need but width wise if you take the 2 bushings end to end they are 2 1/2 inches on the inside. The rear bushing on the a arms (Front and Rear are different) are 3 inches end to end with a 1/2 space between the bushings for grease. I made a diagram for the sizes of the bushings up top. I did think also about rear lower control arms and I believe this will also work for them I don’t have any rear lower control arms but will be getting a set in a couple of weeks and ill let everyone know if they fit. Hope this helps
Old Jul 24, 2006 | 03:18 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I mean the REAR Lower control arms, I saw those boulder bushings and thought about using them for my lower control arms. I already have Spohn units but they are the old design with the cheaper bearings (mine have less that 1000 miles and make a lot of noise already) and the HUGE nut in the middle. They are quite heavy and I am going to be making my own with aluminum tubing. I was thinking I could ise those boulder bushings for the forward bushing instead of rod ends all the way around. But I think they are too wide. I think the bushings on the rear LCA's are about 2 3/8" but I cant confirm this. The ones pictured are 3" wide, but they may be easy enough to modify for what I want to do with them.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
