Has this been an issue?
Old Jul 11, 2006 | 11:00 AM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
Transmission: Super T-10
I just removed the 305 TBI from my car and replaced it with and 355. I noticed that my centerlink is only 1/2" from touching the front of my oil pan. I also noticed that if I turn to the left, all the way, that my zerk fitting from my right tie-rod, hits my oil pan.
The centerlink is straight, along with the rest of the steering linkage. I was told that my idler arm is what may be causing this issue. The mechanic said that if I replace the idler arm, it would drop the linkage down enough to clear the oil pan.
I know that I need to replace my struts and also my strut towers. The struts seem like they would help more than a idler arm.
Has anyone had this issue?
Thanks!
Snowman
Old Jul 11, 2006 | 01:26 PM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
ttt
Old Jul 11, 2006 | 01:55 PM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
I stand corrected. The centerlink IS touching the bottom of my oil pan. I'm afraid that if I hit a speed bump or any lovely pot-hole, I'll cave in my oil pan.
Did they make a different oil pan on the 305's? I am using a standard SBC oil pan.
Thanks for any advise or comments.
Old Jul 11, 2006 | 02:38 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
I took my 305 tbi out and put a 408 in my 89 and I just used a stock oem replacement oil pan from summit and I have no problems with anything hitting my oil pan. I did recently have my front end rebuilt (before the engine swap) so it is possible that replacing some of those parts would be helpful.
Old Jul 11, 2006 | 03:01 PM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
Lt89fb,
Thanks for the reply.
I have a feeling that it's time for a front-end rebuild.
Old Jul 11, 2006 | 05:10 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Originally Posted by snowman_az
Lt89fb,
Yea, i think the centerlink has moved back for whatever reason.
Their shouldnt be any clearance issues with a motor swap since all the pans should be the same up front for SBC's, unless its aftermarket...
Old Jul 11, 2006 | 05:20 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Lt89fb,
I think a rebuild would take care of your problem.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
