Unbelievable!
Old Jul 11, 2006 | 11:10 AM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
Transmission: Super T-10
Unbelievable!
I went to replace my motor mounts, when I put my new motor in and found that I have to drop the lower A-frame, just to get a wrench underneath the frame too hold the nut. Is this normal or am I losing my mind?
By the way, I decided to just put the motor in without replacing the mounts, at this time.
Old Jul 11, 2006 | 11:39 AM
hot trans am's Avatar
Car: 1986 trans am
Engine: 406ci chevy small block
i found the some thing on my T.A. of course this was after i rebuilt the front suspension. you will have to drop the a arms. have fun and good luck.
Old Jul 11, 2006 | 11:40 AM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
I think it's time for me too fork out the bucks and pay someone else to do this.
Old Jul 11, 2006 | 02:30 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Dropping the a-arms definently makes it easier but if you have a properly bent wrench you can hold the nuts through the holes in the crossmember. It would take time and patience to get the right wrench but it can be done. Droppping the a-arms is the way to go though.
Old Jul 11, 2006 | 02:37 PM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
Believe it or not, my crossmember is solid. The only holes that I have are where the A-frames bolt to the cross-member. Just my luck.
Bohemian
Aug 15, 2017 05:11 PM
1988 Massz
Mar 13, 2005 02:38 AM
Matthew91-Z28
Nov 26, 2004 01:56 PM
pardonme2711
Nov 8, 2002 10:01 AM
ski_dwn_it
May 29, 2002 06:55 AM
