centerlink
Old Jul 16, 2006 | 04:28 PM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
Transmission: 700r4 w/ b&m shift kit
centerlink
so the current rebuild is going well, finally got the inner and outer tie rods off. now im stuck trying to get the centerlink. im assuming it should just pop off like the tie rods did with a lil bit of force. the centerlink is tempermental like the tie rods. does anyone have suggestion for its removal?
Old Jul 16, 2006 | 04:46 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Rent or buy the pickle-forks from your auto parts store to pop it free.
Lon
Old Jul 16, 2006 | 08:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
How did you pop off the tie rods?
Whenever I remove tie rods or any other suspension component like that, I hit the piece that the socket pin goes through. For the tie rod, you don't hit the tie rod at all but hit the side of the steering arm that the tie rod end goes into. The tapered pin will pop right out. Same thing for the center link attached to the idler arm and pitman arm. Hit the side of the pitman arm right beside the hole for the center link. Same thing for the idler arm. Use a big hammer and don't be afraid to hit it. If it still doesn't pop off, get a pickle fork.
Ghettobird52
Apr 21, 2020 08:44 PM
Sunny RS
Apr 12, 2005 05:01 AM
Doward
Dec 19, 2003 09:21 PM
SIMON HOLTBY
Mar 10, 2003 01:35 PM
Patrick007
Apr 10, 2002 12:31 PM
