Can My Car Handle 500hp?
Old Jul 23, 2006 | 05:49 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Okay, quick question for all you chassis guys. I have a '92 hard top with SFCs and a completely rebuilt Spohn suspension. I'm willing to do anything to it except ruin my mint interior with a roll cage. I'm building a 396 small block and want to push for 500hp/lb ft, but I'm not sure if the car can take that much power without twisting itself up. If it can't handle the 500, then howabout 450hp? Thanks a lot.
Old Jul 23, 2006 | 09:17 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Come on..yes or no.
Old Jul 24, 2006 | 12:03 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
should be ok. i have seen guys with 600+hp 7-800lbs tq with only SFCs and they havent hurt there cars yet.
Old Jul 24, 2006 | 12:22 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
I don't think you'd have a problem, i'd also recommend a wonderbar, and to just make sure you don't have any serious chassis damage beforehand...ie: cracked gearbox mount, etc...
Old Jul 24, 2006 | 12:39 PM
Shagwell's Avatar
Car: projects.......
My little 355 is making numbers in that range, no issues even with the rage top, but I have an 8-point cage, plus my "sfc's" are way beyond anything store bought.
- That said, yes there are plenty of guys running hardtop, even t-top cars with the same stuff as you, with that much or more power. Mostly it comes down to the harshness of the launch and traction. More traction and more aggressive launches translates to more stress on the chassis and suspension compenents. - again, shouldn't be an issue....
Old Jul 24, 2006 | 12:51 PM
brutalform's Avatar
Go ahead, and add the 500 HP, and have fun...
Old Jul 24, 2006 | 02:49 PM
Tobias05's Avatar
just try not to drive your car sideways too often, hahaha....
Old Jul 24, 2006 | 06:10 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Well then why bother?
Okay, I have the wonder bar and new torque arm and all that fun stuff. I'm guessing a strut tower brace would be in my best interest too. Thanks a lot guys, now I know I can go ahead and build a super Camaro.
Old Jul 24, 2006 | 11:40 PM
EvilCartman's Avatar
Car: '82 Z28
Your car will look like a crushed soda can anywhere after 499 hp. The forces that 500 hp put to the car are so extreme that nothing short of a titanium body will hold it together
Old Jul 24, 2006 | 11:57 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
What if he duct taped the subframe together?
Old Jul 25, 2006 | 03:14 AM
Car: '82 Z28
Gaffer's tape would work better I'd think.
Old Jul 25, 2006 | 11:11 AM
brutalform's Avatar
NOW, Now, play nice guys!
Old Jul 25, 2006 | 01:14 PM
Car: '82 Z28
Whaaaaat, just having a bit of fun
Old Jul 25, 2006 | 02:09 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
499hp it is then!
Old Jul 25, 2006 | 04:34 PM
brutalform's Avatar
I know, me too......
Old Jul 25, 2006 | 05:03 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
it will be fine with the 500
Old Jul 25, 2006 | 08:03 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
I know a guy who seem welded his full car (1986/ 1990-1992 clone) for a pure on race application. Deatails on the project was a little over my head, but, it ran 8s and had 700+ and he had no problems.
Old Jul 25, 2006 | 11:01 PM
Car: '82 Z28
I don't like you anymore
Old Jul 26, 2006 | 12:37 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
You might want to consider upgrading your rear end and/or tranny. In my opinion, an aftermarket tranny cooler is manatory with 500hp, especially if you are going with a higher stall converter (and you should with a new motor, it makes a big difference). Get the biggest cooler you can and your tranny will thank you.
For the rear end, I would switch to synthetic lube. I think a fair number of people are putting that kind of power through a stock 10 bolt, but synthetic lube can't hurt.
Tires might be an issue. I doubt they will last long with that much power!!
Old Jul 26, 2006 | 02:49 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
The tranny and rear will be rebuilt in due time. And a cooler is on the list. And who really needs tires anyway?
Old Jul 26, 2006 | 02:59 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
As Shagwell said, twisting the chassis/body is less about hp level and more about traction. Does your hardtop have a crack where the b-pillar meets the roof on the driver's side? Add 500hp and sticky tires and it might, although the SFC's will help.
Old Jul 26, 2006 | 03:05 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I know 500 is pushing the envelope. But the car will only see a track maybe two or three times a year. And the rest of the year it probably won't be hooking up at all.
Seriously though, I'll be careful.
Old Jul 26, 2006 | 04:24 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
+1, tranny and rear-end. I know a guy pushing 650 rwhp on the bottle with an LS1 and he went through 3 pumpkins and somewhere around 5 axles, both stock and Mosers, until he finally went to a Ford 9". He was a 6 speed on drag radials, running 11's at around 130 mph
Old Jul 26, 2006 | 05:45 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I sure hope your car holds together with the work youve done. If not, my IROC with stock suspension and chassis will have a hard time with the near 400hp that I am about to put it at this weekend =/
Old Jul 26, 2006 | 06:02 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I'll be praying for your IROC. Just go easy on her until you stiffen it up a bit.
Old Jul 26, 2006 | 06:05 PM
Nixon1's Avatar
SFC's before you holeshot it. Or else you'll find your fenders don't quite line up the way they used to, and for some dang reason, your door doesn't open or close right anymore...
Old Jul 27, 2006 | 12:53 PM
Shagwell's Avatar
if she hooks, yes.
"I have seen the b-pillar cracks and shouldered open the door to see the light of the BMR trailer..."
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 25, 2015 11:49 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
