Tierod and centerlink replacement.
Old Aug 11, 2006 | 10:05 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
is it possible to remove the Tierod from the Centerlink and steering knuckle with out a Pickle fork and not damage the centerlink or knuckle? i bought all the parts to replace the centerlink, Tierod ends, and adjusting sleeves.
i was able to change all but the pass side tierod parts at a friends shop easily but the morons at oreillys had a part boxed wrong and that happend to be the last ones they had. well the shop is not open tomorrow and i dont have the money to rent a pickle fork. can i change them without one?
Old Aug 12, 2006 | 12:09 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
a pickle fork is dirt cheap and actually the better tool to use is a TRE puller that will push on the end of the joint stud rather than just wedge like a fork does,
TRE puller is really alot like a pitman arm puller, same principle, on some TRE's you can use an actual pitman arm puller
Powerbuilt Steering & Suspension Tools
these tools are dirt cheap and some places will rent them to you for free
many slight variations in the tools, same purpose though, not rocket science
good luck
Old Aug 13, 2006 | 06:56 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
Take the nut off of the tie rod and whack the knuckle with a hammer. Tap the end of the tie rod stud and PRESTO, your tie rod is off.
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
RS Reaper
Sep 27, 2015 07:04 PM
rb85TA
26
Sep 14, 2015 10:29 PM
scottmoyer
Sep 7, 2015 07:06 PM
mrdevontay
Sep 2, 2015 08:04 PM
