lca relocation brackets with stock lca's
Old Aug 21, 2006 | 12:01 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
I have a set of lca relocation brackets, but dont have nor do i have the money for lower control arms right now.
Should i install them anyways with the stock ones? or do i risk twisting the stock control arms?
Old Aug 21, 2006 | 12:09 PM
Shagwell's Avatar
Car: projects.......
put em on. There's several people on here still running stock lca's with relocates and slicks beating them pretty hard.
- also the lakewood lca's are only $90 from summit. They're as good as any of the rest.
Old Aug 21, 2006 | 09:27 PM
Time2Fly's Avatar
Car: 1991 Z28
Engine: 400 ci LS3
Transmission: Jerico DR4
I second it, your not going to twist your stock LCAs with the power your making. You can run in the 10's with a stick shift on stock LCAs and not twist them.
Old Aug 21, 2006 | 09:37 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
sweet in they go
Old Aug 21, 2006 | 09:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you could always weld in a strip and box them yourself, if you've got a welder.
Old Aug 22, 2006 | 01:02 PM
Shagwell's Avatar
my previous lca's are stockers with poly bushings. I cut the lips off, but welded a piece of box tubing(think it was 1-1/4") into the center, cut so that it's wedged between the bushings. 1.6X 60fts........
- The whole car is currently being changed though.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
NBrehm
Aug 5, 2015 07:57 PM
