crappy launches
Old Aug 24, 2006 | 10:57 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
crappy launches
Hey guys....I got a problem launching. I power brake to about 1000 rpms and then i dump the brake and gas it. Before I put the intake mods on my car, I didnt have much of a problem hooking up. Now I hear three chirps before I start moving. Am I launching my car wrong or do I need some suspension upgrades? My buddy said he can sell me his edelbrock torque arm for like 100 bux. Please help thanks
Old Aug 24, 2006 | 11:35 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
try less throttle, but if you're running street tires at the track you'll never hook up to your potential.
Old Aug 24, 2006 | 01:41 PM
Shagwell's Avatar
Car: projects.......
- the tq arm is the 2nd to last thing to upgrade. Subframe connectors, the lca relocates, then lca's, then tq arm, then panhard(largely depending on application) - Try launching a little softer. Upgrades mean more power, thus making it easier to spin the tires.
also, if you do a search, you'll find some reasons you may not want to even try an edelbrock tq arm......
Old Aug 25, 2006 | 01:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
whoa, 3 chirps? Not one long chirp, but three... That sounds like wheelhop -> LCA'RB's.
Yea, don't worry about a torque arm yet.
Old Aug 26, 2006 | 02:19 AM
EvilCartman's Avatar
Car: '82 Z28
I'd say to try replacing your old warn out LCA bushings with poly first.
Old Aug 26, 2006 | 11:56 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
screw replacing the bushing you can get some lakewood tubular lcas with poly bushings for like 88 bucks, they took away all my wheelhop, and they even helped both tires turn over when the posi unit was worn out
Old Aug 26, 2006 | 09:00 PM
Car: 92 Camaro
Axle/Gears: S60 373
thats something else i want to look into. i want to get a posi unit for my car but summit was asking me how many spline and other stuff i dont know can anybody help me out with what posi unit i need for my car?
Old Aug 26, 2006 | 09:04 PM
Car: 92 Camaro
Axle/Gears: S60 373
So you are saying give it like 3/4 throttle instead of full? Also do you give it less throttle all the way thru first gear or after a certain mph go ahead and floor it? thanks alot guys
Old Aug 26, 2006 | 09:05 PM
Car: 92 Camaro
Axle/Gears: S60 373
So after what speed should I start to floor it after I get rolling?
Old Aug 26, 2006 | 09:13 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
I think you will have to figure that out with practice. Posi rear and a good set of tires will make a world of difference. If its not your daily driver I would get a set of drag radials. If its a T-top car then definately get the subframe connecters. Just my 2 cents. Good Luck
Old Aug 27, 2006 | 02:37 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
With a little practice you can learn to roll into the throttle. Try coutning out 1 second for starters and if there i no spin try a little faster. Maybe try starting out from an idle. Good luck.
Old Aug 28, 2006 | 01:42 PM
Shagwell's Avatar
Every car launches differently. There's no mystical perfect throttle percentage, suspension angle, etc.... - Trial and error.
W/o a posi and decent tires, you will always have traction issues. You may be able to get it to not spin, but then you'll be leaving softer, thus going slower.
Try leaving at an idle...try leaving at 750, instead of 1000...try rolling into the throttle...trial and error. -
- I do agree that it you're getting several chirps, not one, that you have a wheel hop problem that should be addressed before something gets broken....
69GTOby
Apr 18, 2016 02:34 PM
darwinprice
17
Oct 11, 2015 11:51 PM
mfp189
Sep 27, 2015 09:25 AM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
