Spohn adjustable torque arm is on
Old Aug 25, 2006 | 03:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
finished up my torque arm installation a few days ago. right after i tore the TPI down to replace gaskets to fix an oil leak. lol
anyway, i'm very pleased with the build quality of the torque arm. i got the adjustable arm with DS loop. everything was bolt in, fit was good. there isnt much room under there and the tolerances on that torque arm were good. clearance on everything was fine, although it was very close in some spots. that just shows quality of the fabrication of that spohn piece.
i got it all bolted on without too much problems. replaced the trans mount with the poly piece that spohn sells as well.
set pinion angle to around -1.5 degrees and took it for a drive the last 2 days. it seems to be good. trans mount is solid and no more bumping around like before. i have better street traction now as well. i'm very happy with that.
its kinda noisey tho...it moves around under there abit with that sliding/pivoting front mount. i left that bottom mount loose like it says so it will move around some. i'm guessing it is workin as it should. i'll have to recheck all the bolts and make sure they are snug everywhere before i take it to the track to see if i gain anything. problem is, i am goin back to school now, and have to wait till october to race again when they move test and tune to saturday afternoons instead of wednesday nights. but i'm expecting some gain as the new trans mount will keep the torque arm planted. when i went to track last time, i pulled a 1.80 60 foot but the trans mount was starting to go bad and moved on me alittle. thus hurting traction. i'm hoping for mid 1.7's
i'll try and get some pics uploaded here shortly.
Old Aug 25, 2006 | 06:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Got some quick pics under the car. still gotta clean up some of the oil leak mess...but i got alot of it off so far. lol
Attached Thumbnails Spohn adjustable torque arm is on-tqarm1.jpg   Spohn adjustable torque arm is on-tqarm2.jpg   Spohn adjustable torque arm is on-tqarm4.jpg
Old Aug 25, 2006 | 11:07 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
looks like at op notch piece, spohn does it again
Old Aug 25, 2006 | 11:21 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
I've had Steve's torque arm on my Z for about 18 months now. I am still impressed when I climb under the car. This piece is a work of art.
Old Aug 26, 2006 | 06:15 PM
Raiderfan's Avatar
Car: '92
Looks good!
I really like that cross member.
Too bad it hangs down like that, i'd get it for my car but i'm afraid to drive over a peanut with my current setup.......
Old Aug 27, 2006 | 11:20 AM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I like that arm. I have their driveshaft loop with a stock arm, but i think maybe this winter i will switch over to that setup.
Cool that it fits with no problems.. is that a stock driveshaft?
Old Aug 27, 2006 | 12:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Looks good!
true, it angles downward some....but my exhaust is still the lowest point..it sags at the cat area. so to me, its no big difference over stock as far as driveability is concerned. i've taken it to a few bumpy roads and have had no problems yet.
and yes, its the stock driveshaft.
Old Aug 27, 2006 | 10:29 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
after viewing many posts like this, ive fully decided on getting a Spohn TQ. arm for my 87 IROC,
my current, stock one is ok, but the trans bushing is split down the middle, causing the rear end to pop around when shifting under heavy acceleration... thats bad...
the spohn one looks real nice, and from waht i've heard preforms great.. especially bieng adjustable
ive jsut heard a few times that poly-bushing make a lot of noise,, but thats ok when uve got a good exhaust and sound system i guesss
nice tq arm man, im glad to hear that it went in easy for u. ill be getting the exact same one, with the D.S. loop too
Old Aug 28, 2006 | 12:10 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah u should love the spohn piece. the install was pretty straight forward like i said, and i have had no problems so far. good luck with yours!
Old Aug 28, 2006 | 11:09 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
shouldn't the driveshaft be more centered in the driveshaft hoop? in the pic it looks as if is very close to the top of the hoop.......
Ray
Old Aug 29, 2006 | 12:23 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
it should be, but it has room to play. it cant get any closer else it will contact the torque arm itself.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
