Mashed front bump stops - a problem?
Old Aug 29, 2006 | 03:45 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
A while ago I redid my sway bar bushings, and I saw the front bump stops on the a-arm were all smashed up, as if the suspenion was constantly bottoming out. I believe everything is stock, except for the sway bar bushings I put in.
Is this an emergency sign that I need knew springs?
The car is a 91 RS with F41
Old Aug 29, 2006 | 03:57 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Well the car is 15 years old, so it's probably due for new springs. But the bump stops are probably just deteriorated (they're 15 years old too). If the car was constantly bottoming out like that, you would definitely hear/feel it.
My rear bump stops aren't even there anymore. Just two bolts and a metal bracket.
Old Aug 29, 2006 | 04:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
ES makes poly replacements.
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Fronzizzle
Aug 9, 2015 01:15 PM
