How to get spindle off the ball joint
Old Aug 28, 2006 | 04:45 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
AAAHhhhhhhhh!@!!!!!!!
She wont give it up. I got the tie rod off. But I'm having one hell of a time getting the spindle off the a-arm. Any tips/hints would be greatly appreciated.
Old Aug 28, 2006 | 05:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Pickle fork or a couple of ball-peen hammers.
Old Aug 28, 2006 | 05:32 PM
ChrisH821's Avatar
Car: 88 sport coupe
or you could smack the area on the spindle around the balljoint with a good heavy dead-blow hammer a bunch of times... just make sure youre supporting the control arm
Old Aug 28, 2006 | 06:02 PM
got the pickle fork.....was trying to pry it off alone with that but couldnt get it to budge. Ill try with the hammers
Old Aug 28, 2006 | 06:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The pickle fork isn't a prying tool, it's a wedging tool. Hit it with a bigger hammer.
Old Aug 28, 2006 | 06:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
After supporting the A-arm, I left the ball joint nut at the top of the threads, and whacked it really good with a small-handled sledge - she popped right off. I was replacing ball joints anyways, so damage to ball joint wasn't an issue for me.
Old Aug 28, 2006 | 09:29 PM
1Bad3rdGen's Avatar
Car: 92 Firebird Convert & 91 Camaro RS
Engine: 305 L03 TBI
Transmission: 700r4 & T5
Axle/Gears: Stock
use a tie rod or pitman arm puller. rent one for like 15 bucks at a auto parts. makes the job easier.
Martin
Old Aug 28, 2006 | 11:16 PM
thanks for all the advice. Didnt realize the fork was a wedge. I tried prying again before reading this thread and gave up a few hours ago. I'll give it another shot tomorrow by wacking it really good. Thanks for all the great input.
Oh and tryng to pry with the fork only tore some of the rubber of the ball joint. Oops. Another casualty, but after today I realize I should probably replace them while I am here.
Trying to get my big brakes (LS1 style) on.
Old Aug 29, 2006 | 06:12 PM
ok i got it.. I removed the caliper and rotor and got the fork in position, perpendicular to the car and gave it a WHACK with a large sledge hammer. Came loose in 2 swings.
Now for those ball joints.
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
