Anyone in the 9's w/MT ET Street Radials?
Old Oct 13, 2006 | 01:06 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
what kind of suspension setup and what size tires?
Old Oct 19, 2006 | 10:37 AM
radialtireking's Avatar
Car: 85 Camaro
Engine: 437" small block
Transmission: glide
Axle/Gears: 3.70
I have been 9.84 on motor and 8.96 on spray on a 275/60 M/T. Spohn torque arm, LCA's, LCA relocation brackets, panhard, and drag race rear sway bar. Up fron I have spohn pro drag coil over kit and koni SPA1 struts.
Old Oct 19, 2006 | 11:49 AM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
On 275's? Your either nuts or bluffing.
I know a guy that runs high 11's at a 5800 altitude. So he can run 10's easy at sea level. He is running 315's on an 11" wide rim. He's only pushing around 600 crank horsepower.
Old Oct 19, 2006 | 01:04 PM
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
Nuts...no....bluffing definetly not! What is not to believe. If you search around the net you will see many cars have been in the 7's on 315 and 325 radials and I know for sure Artis Houston has been low 8's on a 275. If you check out the Pacific Street Car Association's wild street class you will find many 8 and 9 second cars on a 275 radial since that is all the class allows. Both David Wolfe and Dwayne Guttridge have been in the 7.40 range at 190 plus on 325s and 315s respectively . In my area there are at least 30 radial tire cars in the single digits. The shakedown at etown just had an outlaw drag radial class with numerous cars in the 7's and a bump of around 8.60 for a 16 car field.
Here is my rig and the timeslip.
you can see the tread in this pic
Old Oct 19, 2006 | 02:05 PM
Shagwell's Avatar
Car: projects.......
(nice car) - there are several cars getting into the 7's down here on the 275's. You should see what we do in 10.5 outlaw.........
Old Oct 19, 2006 | 02:32 PM
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
Thanks! There are a bunch of outlaw 10.5 guys in the high 6's in my area. I was just at englishtown this past weekend and saw Tim Lynch go 6.66 on 10.5's.
Old Oct 19, 2006 | 03:36 PM
Camaroal's Avatar
Car: 98 Camaro
Engine: 441ci LS7
Transmission: th350
Axle/Gears: 4:10's
I was there also guys are flying on both drag radial and 10.5's
Nice car radialtireking
Old Oct 19, 2006 | 05:06 PM
brutalform's Avatar
THAT IS ONE OF THE NICEST, AND FASTEST THIRD GENS I EVER SAW!
I saw some of your pics in some other threads, but they were of your front suspension, on a lift, I suppose.
I was reading this thread, and was going to ask if you had any pics of it. Then you posted some up.
BTW, where in Pa are you from radialtireking?
Old Oct 19, 2006 | 08:31 PM
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
I live in Macungie. It is near Allentown.
Old Oct 20, 2006 | 12:33 PM
brutalform's Avatar
Yes, I know exactly where it is. I did some work in that area, with my company, about 12 years ago. Macungie, Trexlertown, Emmaus, and Allentown. Thats a sweet car.
Old Oct 20, 2006 | 02:46 PM
Shagwell's Avatar
I've yet to run 1/4 in the 10.5 car. I haven't found the nads yet. I've been 4.76 @ 160 in the 1/8. I'm just a bit leary of running over 200 in the 1/4 on a factory front stub, plus that last 1/2 track is damb hard on parts. - we'll see how I feel in the new car.
- my old man just had a nasty crash(1st ever in almost 40 years of racing for him) 125mph t-bone into the wall, 1/8 out through the shut down on the roof. He was competely unhurt(thankfully) but the 'maro ain't so good. So, I'm about to build a new car(3rd gen TA) for outlaw 10.5, factory front suspension, 3000lbs, factory firewall, etc with a 500" bbc and a monster of a turbo on methanol. Should be fun, especially since I'm gonna shift it, though it will have a bruno's drive...
Old Oct 22, 2006 | 01:38 AM
nickx07's Avatar
hey whats up. has anyone heard of rick head. a few years ago he ran at orlando and was running mid 7s. if you take a look at his car its mostly bolt ons.
my dad's 3rd gen ran a best of 8.83 with simple bolt ons and the m/t 10.5w tire 29in tall.
Old Oct 22, 2006 | 09:07 AM
brutalform's Avatar
What do you consider bolt ons? Getting a third gen to run high 12s, or low 13s, with bolt ons is one thing, but, 7s, and 8s?
Old Oct 22, 2006 | 10:45 PM
CrazyBear's Avatar
Car: 1987 Camaro,'89 firebird
Engine: 305 quadjet, 305 tbi
Axle/Gears: 2.73. 3.2xs
with simple bolt ons on a 505 racing bred big block only pushing 700hp.
Old Oct 22, 2006 | 11:41 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
hey radialtireking, what kind of rear suspension do you run? as in shocks and springs? and do LCA relocation brackets really work?
Old Oct 27, 2006 | 09:46 PM
nickx07's Avatar
simple bolt ons as in adjustable panhard bar, adjustable lower controll arms, ford 9in rearend, adjustable torque arm and welded in subframe connectors. on the inside of the car we have a costom roll cage. the shocks are koni udjustibles and springs are stock. the ride hight is just about stock hight. the front suspention is completely stock with the exception of struts and a steering brace.
here i have an attached video of our low 9sec run after our 8.83 run. the supercharger tube blew off.
YouTube - 9.12 run south pac 03
my dad used to drive this car everyday for work as a police officer. since then we freshend up the engine and added the suppercharger. the engine is a 406 small block chevy with a f-3 procharger. its never been on the dyno but our calculations bring horsepower to about 1000 at the wheel.
cheesehomer
Dec 31, 2015 08:48 AM
Nervous2
Oct 8, 2015 10:53 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
fasteddi
Sep 10, 2015 09:32 AM
