Swaybars?
Old Oct 16, 2006 | 04:03 PM
Bad-Newz's Avatar
Car: '88 Camaro / '91 Camaro RS
Engine: 3.1L MPFI V6 / 3.1 MPFI V6
Transmission: 700R4 / 700R4
Axle/Gears: ??? / 3.23's
Swaybars?
What is the best size for sway bars on a third-gen Camaro? Does the general rule of bigger is better apply? Is there such thing as too big???
Old Oct 16, 2006 | 09:09 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
36mm is a good, and big size I think.
I think when u go over 36 the bar interfere with one of the steering rods
or something, not sure though.
Old Oct 16, 2006 | 09:35 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Transmission: Built 700r4
Axle/Gears: 3.73's w/ stock axles
I'm no expert, but I've read and learned alot here. I believe that there is such a thing as too big. If the rear is too big, it will be too stiff and break loose early and make the car handle worse. And if the front is too big compared to the rear, the car will understeer.
I got the spohn set (front and rear) off of their website and find that they are matched really well. The car pulls around corners like its on rails now. No matter how many times I do it, it still brings a smile to my face every time.
Do a search and you will probably fing a better explanation than mine. I only speak from my experience.
Old Oct 17, 2006 | 05:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The biggest stock sway bars are hollow 36 mm front and solid 24 mm rear. These are found on some Camaros, 89-92, and some Firebirds, 86-92. They may still be available from GM. The 36 mm is 14094344 and the 24 is 10035033. Recommended.
JamesC
Orr89RocZ
Apr 25, 2016 08:28 AM
grafx
Aftermarket Product Review
Dec 10, 2001 12:27 PM
TBIWorks
Dec 4, 2001 01:35 PM
TBIWorks
Nov 29, 2001 01:03 AM
Trevor 91 Formula
Feb 7, 2001 02:06 PM
