tranny crossmember bolt issue? HELP
Old Dec 8, 2006 | 10:44 AM
ChampionN84's Avatar
Car: 91 Camaro Z28
I recently replaced my trans mounts on my car. When i was placing the crossmember back into the car, one of the cross members bolts inside the frame is strip. Any have this issue and how to you resolve the issue? Also is it possible to have the frame close to the crossmember refabed by a body shop and has any ever paid to have this done before? what are the cost involved? Thanks for the help in advanced.
Old Dec 8, 2006 | 11:25 AM
Happens all the time.
Sometimes you can get up in there through one of the other holes, and grab it with Vise-grips or something.
One thing that always works is to use about a 1¼" hole saw from the interior, and then patch that back after you're done.
Old Dec 8, 2006 | 07:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Naw, What I did was drill it out clean and drop a bolt in though the top though one of those oval access holes in the subframe. You can slide up an open end up there and hold the top bolt and use a nut then to bolt up the X member. Worked flawless for me this way. No way am I drilling though the floorboard to get to a bolt.
Old Dec 10, 2006 | 02:03 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's exactly what I did. I did all 4 this way. I also didn't need to hold the bolt head, once I started tightening it, it pulled the bolt and held it in place, so I just had to tighten the nut. 3/8"-16x1" long bolts
Old Dec 10, 2006 | 09:17 AM
BOTTLEDZ28's Avatar
Transmission: A4
I drilled out the threads and retapped it for a bigger bolt. This worked fine for the first 20-30 times I took the bolts out but I think its happening again. I cant go back and drill it our again. There proberbly isnt much wall thickness left. I will either pull the carpet and cut a hole and weld in a new set of nuts or fish the bolts through the holes in the side of the framerail. Havent decided yet. I guess the only downside to driling a hole inthe floor is that your proberbly want to make sure your measurements are right the first time so you only have to drill one hole.
Old Dec 10, 2006 | 07:25 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Just run a 7/16-11 (or is it 14?) tap through the hole and put in new bolts. Thats it.
Old Dec 11, 2006 | 06:59 AM
It's 14.
Which would work great; until you realize that it's just some kind of cheeeep chinesium nut captured inside a little sheet metal cage, and about half of the problem is that the cage ceases to hold the nut, and it certainly won't hold it still against the force of a tap; and that even if you do successfully tap it out, now you have EVEN LESS chinesium left up in there holding everything together.
Much better deal all the way around to get rid of that cheap one-time usage (factory assembly) stuff that you should consider yourself lucky if you get to re-use even ONCE, and replace it with something more secure.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
spaigo
Aug 21, 2015 07:46 PM
crazynights
Aug 21, 2015 06:53 AM
Elliswon
Aug 10, 2015 12:33 PM
