removing/installing k-member?
Old Dec 30, 2006 | 02:15 PM
AZZ28's Avatar
Car: 1990 IROC
Engine: l98
It looks to be a pretty straight foward job but I figure it would not hurt to ask some questions. Do I need an engine hoist to support the engine while I remove the k-member, or is there another way to support it, like placing a jack with some wood under the oil pan?
For those who have done this before I would really appreciate some advise like things you could have done to make it a little easier. I would appreciate any tips, thank you for your time.
Old Dec 30, 2006 | 11:07 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
your best bet is a hoist to support it but you can use a block of wood under the oil pan, remove the springs and a-arms, 6 bolts and a couple support brackets hold the kmember up, watch out for the brake lines attached to it.
Old Dec 31, 2006 | 12:09 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
different ways
i had my motor out,but you can swap the whole k-member with spindles etc. still attached,the springs are the problem
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Mdenz3
Sep 17, 2015 08:36 AM
tricky1
Aug 23, 2015 01:17 PM
overdriv
Aug 20, 2015 03:52 PM
NBrehm
Aug 5, 2015 07:57 PM
