Moog Spring Replacement Guys
Old Jan 12, 2007 | 06:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've attempted to discover as much as possible about stock spring rates but found nothing that seemed definitive. The car is a simple daily driver, which will never see the track in any form. So the question: Are the Moog 5662 fronts (748) and 5665 rears (107), along with Koni Reds or Bilstiens HDs, going to beat me to death or will I be a happy boy?
JamesC
Old Jan 12, 2007 | 02:46 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Well, those are the springs I used along with the Bilstien OEM style rear shock. As for the front struts I used the Koni adj. It is stiff but I also have poly bushings throughout the front and rear suspension. The ride is OK, but not like a stock IROC. I purchased a 86IROC with 30000+ miles on it and it rides smoother than my 85. My research indicated that those are the correct springs for the 85IROC and I feel the rear OEM bilstiens are good shocks. The front OEM struts are where I believe an upgrade is necessary. As for a daily driver, I say buy the replacement Bilstien or KYB strut. Then again, that's just my opinion. And you know what they say about that! Badman
Old Jan 12, 2007 | 02:53 PM
JamesC's Avatar
Rougher?
JamesC
Old Jan 12, 2007 | 04:15 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Yes, rougher but tighter turning.Badman
Old Jan 12, 2007 | 08:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think the 5662's are 706 or so, but I know that's been a running debate...
I would think the Bilstein HD's would make it harsh on small bumps, where the tough shock damping has the most effect. hmm eh?
Old Jan 17, 2007 | 05:27 AM
JamesC's Avatar
Other replies?
JamesC
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
Street Lethal
Aug 14, 2015 08:25 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TA8487
Aug 11, 2015 09:02 PM
