WS6?
Old Jan 27, 2007 | 08:57 PM
baroner's Avatar
Car: 87 trans am WS6
WS6?
Ive got an 87 trans am and im not sure if its got the ws6 package or not. It has the snowflake style rims and there are 16 inches. It also sais performance suspension on the dashpad inside the car. I heard that you could only get 16s with the ws6. Anybody know if ive got it or not?
Old Jan 28, 2007 | 11:45 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
depends on the year
the earlier ws6 didnt come with 16"
i dont know if 87 did though- but i know in 85 there wasnt any 16" yet
look for rear disc brakes
thas the first big thing the WS6 had
and also quick steering
and larger sway bars
etc.
what does your RPO sticker say ?
Old Jan 28, 2007 | 09:10 PM
wrapper8758's Avatar
Car: 1986 trans am, 1985 TRANS AM WS6
Engine: 305 4bbl,305 TPI
Transmission: 700r4,700R4
Axle/Gears: STOCK POSI DISC
Like Fast68 said, disc brakes,larger sway bars,and check RPO sticker if its still attatched inside of your console compartment. One of the codes will say WS6 if it is one.
Old Jan 29, 2007 | 12:14 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Originally Posted by Fast68
...look for rear disc brakes...
Nope, my 88 Firebird Formula has the WS6 RPO code and drum rear brakes. Or I should say HAD rear drums. I've since converted to rear disc brakes.
Lon
Old Feb 1, 2007 | 10:04 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
I had drums on my 88 WS6 as well.
Old Feb 1, 2007 | 10:34 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My 86 Trans Am WS6 had 9 bolt w/ Discs while both of my Formula's, 88 and 90 both had 10 bolts w/ drums, the 90 was an open rear as well.
Old Feb 17, 2007 | 07:48 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
u got any pics of your car id like to see wut u got
Old Feb 17, 2007 | 08:06 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
i got a 86 trans am with rear disks and it had the performance sticker on the dash, the only way to really tell would be the RPO codes on the inside of the arm rest pad, that would be the easiest, orrrr u could just find a 350TPI like my 87 formula 350 TPI bc they all come stock wit all the good stuff!! lol. i actually ripped up the carpet this past summer to replace it and i found the ORIGINAL ORDER SHEET FOR MY CAR from the factory under the carpet under the driver seat, it had all the codes for everything my car came wit, the plant number and place, paint, interior, drivetrain, engine, suspenstion, to each spec of the front and rear shocks etc... even the plant and dates it was made on and the car dealer that it was sold to, to the interior parts and who installed them! crazzzzy!! maybe u could find that lol
Old Feb 17, 2007 | 08:39 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
My parts car ('91 Formy WS6) had the WS6 package, 16inch wheels, and rear drums. It has the 36mm front sway bar. Just not too sure on the rear bar, though. Would it be 24mm?
Old Feb 17, 2007 | 10:47 PM
Car: 87 TA clone
it depends...they used diff sizes on the cars for all years and it doesnt really matter wat performance package they have on them, some WS6's had the small rear sway bar and some had the larger one, i guess mine since its a stock350tpi that mine came with everything including the largest sway bars...since the really put everything into them as there fastest car. the only way to tell would be to measure the rear sway bar by using an energy suspension cut out ruler etc or a micrometer etc...
Old Feb 17, 2007 | 10:52 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I need to go find the micrometer....or get the wrench set out. That'd work. I kinda wish it was the 22mm. I need a smaller rear bar.
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
dbrochard
Sep 7, 2015 09:41 AM
neekolzun
Aug 24, 2015 04:59 PM
