big tires
Old Feb 1, 2007 | 12:58 PM
85SILVERBULLET1's Avatar
Car: 85 Trans Am
Engine: 383 ci
Transmission: Liberty Geared Tko 600
Axle/Gears: Moser 9" 4.11 gear wavetrac locker
big tires
i have bfg 325 50r15 drag radials on centerline wheels but they dont have the right backspacing. 3" back space and 10" wide. they stick out of the wheel wells anout 2.5" to 3" the bfgs are roughly 11.5 wide(section width) and 27 inches tall. do you think that i can get away with a 5.5 back space and an 8 inch wheel. or do you think i should run a 4.5 back space and a 10 inch wheel. I really dont want the tires sticking out like they do now.
Old Feb 1, 2007 | 07:20 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
I doubt if you get those 325's in there.
You also have your backspacing wrong...4.5"bs with the 8"rim...
5.5"bs with the 10
Old Feb 2, 2007 | 12:44 PM
Car: 85 Trans Am
Engine: 383 ci
I read somewhere that if you cut off the bump stops and do a little beating you can make them fit. what backspace do you think i need in order to make them fit.
Old Feb 2, 2007 | 01:21 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
15x8 4.5bs
15x10 5.5bs
although with those size radials, you'll need to do work regardless, and they won't fit on a 8" rim, only a 10"
Old Feb 2, 2007 | 02:41 PM
Car: 85 Trans Am
Engine: 383 ci
ok so 10" wheel 5.5 bs. will i have any issues other than the bump stops and some minor fender beating? do you know if you have seen any pics of where and how much i need to cut off and beat. Any possible pics of a 10 inch wheel with the 5.5 bs.
Old Feb 2, 2007 | 05:15 PM
xpndbl3's Avatar
Car: 1984 Z28
there's tons of pics on here, but they won't show what you need to beat/remove, also make sure that the rear end is centered in the chassis for the best fit. I sure hope this car is running super super fast, otherwise 275 drag radials will be fine and 325s will be too much tire and slow the car down. My buddies 10 second ls1 picked up .2 from the switch back to 275s and his 60' stayed the same essentially. The car MPH'd higher as well. You would also need to roll the fender lip and cut out the bump stop area, although with 28x10.50 slicks I still have my bumpstop.
Old Feb 2, 2007 | 05:24 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
nice conversation about just that size tire going on right now...
https://www.thirdgen.org/forums/fabr...ng-rubber.html
make sure and register at yellow bullet .com to view the mini tub on a third gen thread
Old Feb 2, 2007 | 05:50 PM
Car: 85 Trans Am
Engine: 383 ci
I am not real sure how hard the car is going to run but i am hoping for low 11 sec times at 5000 plus feet in elevation. I am running a worked up 383 with aluminum heads and i am going to run a 200 hit on it. I bought these tires because they were similar in size according to the 28x11.50 hoosiers i have. I may end up burning these tires up and buying the smaller tire but it is what it is after you have al ready purchased the tires.
Old Feb 2, 2007 | 09:15 PM
xpndbl3's Avatar
Car: 1984 Z28
scott you got a link to that website, i tried pocking around but didn't find it.
Old Feb 3, 2007 | 06:52 AM
http://www.yellowbullet.com/forum/sh...ad.php?t=14955
are you registered over there? if not you cannot view the pic`s it is in the stock suspension section
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
webeeZ28
Sep 14, 2015 12:00 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
84 TA NV
Sep 6, 2015 08:02 PM
