Replacement Struts.
Old Feb 3, 2007 | 06:24 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Replacement Struts.
What would be the Cheapest struts of the same quality as the OEM struts my car has on it? They have 183,000 on them and only one of them has gone bad. Id like to think that i could get a set that would last at least half that long.
Sub $100.
Old Feb 4, 2007 | 02:50 PM
Kandied91z's Avatar
nothing of the same quality. that many miles if they are original they are all bad.
Old Feb 4, 2007 | 02:59 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
parts store cheapies would be a vast improvement and under $100
Old Feb 4, 2007 | 03:46 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
KYB GR2's can be had from Tirerack for right around $100. Parts store cheapies will run around $70 a pair. The cheapies will probably be equivalent to the base model struts.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
